[petsc-dev] git problem
Matthew Knepley
knepley at gmail.com
Fri Sep 9 21:45:36 CDT 2016
On Fri, Sep 9, 2016 at 8:54 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> This came up and I haven't seen it before, google is not helpful in
> resolving it.
> git pull http://bitbucket.org/vlc1/petsc vlc1/dmcomposite
> fatal: unable to access 'https://bitbucket.org/vlc1/petsc/': SSL
> certificate problem: unable to get local issuer certificate
Don't use https://, use the ssh:// protocol. You might have to fix it in
your .git/config
Matt
> Meanwhile things like
> $ git checkout master
> Switched to branch 'master'
> Your branch is behind 'origin/master' by 4 commits, and can be
> fast-forwarded.
> (use "git pull" to update your local branch)
> ~/Src/petsc/src/ts/examples/tutorials (master<) arch-basic
> $ git pull
> Updating acfa351..b3a4586
> Fast-forward
> bin/maint/buildtest | 7 +------
> bin/maint/runhtml.py | 1 +
> config/PETSc/Configure.py | 4 +++-
> src/ksp/ksp/examples/tutorials/makefile | 8 ++++----
> src/mat/examples/tests/makefile | 30
> 5 files changed, 24 insertions(+), 26 deletions(-)
> ~/Src/petsc/src/ts/examples/tutorials (master=) arch-basic
> seem to work fine. I can also go to http://bitbucket.org/vlc1/petsc via
> the browser and it displays the repository fine. So what is the issue?
> Thanks
> Barry
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160909/a58ffad2/attachment.html>
