[petsc-dev] Bug in PCSetUp_FieldSplit/PCReset_FieldSplit
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Nov 25 23:02:11 CST 2016
   Sander,
    Thanks for the patch, I have put it into the branch barry/Sander/fix-pcreset-fieldsplit and confirmed that it does
support reset (after fixing some bugs) and merged it into next for testing. Can you try it and see if it resolves the difficulties you were having?
   Barry
Before submitting patches you should try the test codes with -malloc_test or under valgrind, you would have found some memory leaks due to bugs in your patch and from those found the bugs in the patch you sent.
> On Nov 22, 2016, at 3:10 AM, Sander Arens <Sander.Arens at UGent.be> wrote:
> It works now for the particular case when there's a SNESReset before a SNESSolve, but when you put a SNESReset and SNESSolve again after the first SNESSolve it breaks again (I noticed this first  playing around with TSArkimex when it broke at this line).
> Destroying the fieldsplit linked list in PCReset_FieldSplit seemed to work (see diff file)...
> On 21 November 2016 at 21:02, Matthew Knepley <knepley at gmail.com> wrote:
> Okay, try out the fix in next.
>   Thanks,
>     Matt
> On Thu, Nov 17, 2016 at 3:11 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Nov 17, 2016 at 1:22 PM, Sander Arens <Sander.Arens at ugent.be> wrote:
> I think there's a bug in PCSetUp_FieldSplit or PCReset_FieldSplit. I can get this by putting a SNESReset before the SNESSolve in snes ex77 and running ./config/builder2.py check src/snes/examples/tutorials/ex77.c. Can somebody reproduce this?
> You are right. Fixing...
>    Matt
> Thanks,
> Sander
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
> <fieldsplit.diff>
