[petsc-dev] MatSetValues (Fortran)
    Tabrez Ali
    stali at geology.wisc.edu
    Tue Nov 22 20:37:58 CST 2016
Yes, that was the complete message (GNU FC). I am attaching a test case.
Tabrez
On 11/22/2016 07:51 PM, Satish Balay wrote:
> It will also work if you use MatSetValues11() or MatSetValues1n() -
> but then - you will be using F77 mode of calling that routine - and
> bypassing the f90 interface definition [that supporsedly provides type
> checks]
> It would be good to figure out whats hapenning here. Is what you sent
> the complete error message? How about a minimal code snippet that we
> can compile to reproduce the error?
> Satish
> On Tue, 22 Nov 2016, Tabrez Ali wrote:
>> Hello Satish
>> It works fine if I use MatSetValues0 instead of MatSetValues.
>> Tabrez
>> On 11/22/2016 07:25 PM, Satish Balay wrote:
>>> f90 interface definitions for MatSetValues were added. So if you are
>>> including petscmat.h90 - there should interface check by the compiler.
>>> https://bitbucket.org/petsc/petsc/commits/4d03fd2beba63756fb8890bf1826f747a8ce8800
>>> Looks like this check is failing. Does the compiler print more info on
>>> why it didn't find a match?
>>> Or is the compiler complaining about using MatSetValues0 - instead of
>>> MatSetValues here?
>>> https://bitbucket.org/petsc/petsc/commits/3b494cfec78d3366d5cde5f82eed4f6aebe3762b
>>> If you can reproduce this in a test code - that would help.
>>> Satish
>>>> Hello
>>>> I am using petsc-dev and today I got the following error (below) while
>>>> compiling the code. I guess this has to do with the Fortran interfaces but
>>>> I
>>>> cannot spot what's wrong. Any ideas?
>>>> Tabrez
>>>> /opt/mpich3/bin/mpif90 -c -Wall -ffree-line-length-0
>>>> -Wno-unused-dummy-argument -g    -I/home/stali/petsc-dev/include
>>>> -I/home/stali/petsc-dev/arch-linux2-c-debug/include -I/opt/mpich3/include
>>>> -o main.o main.F90
>>>> main.F90:177:75:
>>>>         call
>>>> MatSetValues(Mat_K,ef_eldof,indx,ef_eldof,indx,k,Add_Values,ierr)
>>>> 1
>>>> Error: There is no specific subroutine for the generic ‘matsetvalues’ at
>>>> (1)
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161122/611ad6a4/attachment.bin>
