[petsc-dev] Fwd: [trilinos/Trilinos] strange versioning of Chaco in	Trilinos. (#836)
    Matthew Knepley
    knepley at gmail.com
    Mon Nov 14 10:03:16 CST 2016
I looked at this. Someone took the old Chaco source, split in into 30+
directories for no apparent reason, and then
mixed in some Fortran and CMake. Wow.
   Matt
---------- Forwarded message ----------
Date: Mon, Nov 14, 2016 at 9:49 AM
Subject: Re: [trilinos/Trilinos] strange versioning of Chaco in Trilinos.
(#836)
To: trilinos/Trilinos <Trilinos at noreply.github.com>
Cc: Matthew Knepley <knepley at gmail.com>, Mention <mention at noreply.github.com
OK, that was done about 15 years ago to permit decomposing on more than 32K
processors.
I was unaware that anyone other than seacas tools was still using chaco, so
didn't update the documentation at that time.
There have also been some changes to the memory allocation functions, but
their use is probably all internal to the library and won't affect external
users; they are also probably all pass-by-value changes so wouldn't affect
users.
The main areas probably causing issues are pointer arguments which changed
from short to int. Hopefully the compiler will warn about all of these
uses, so they should be visible and not cause silent corruption.
I will add a note to the Chaco documentation on the SEACAS github site and
will also update the version number in the CMakeLists.txt file to be 3.0.0;
I will also add a version number to chaco.h
CHACO_VERSION_MAJOR, CHACO_VERSION_MINOR, CHACO_VERSION_PATCH. which will
be 3, 0, 0 respectively.
You are receiving this because you were mentioned.
Reply to this email directly, view it on GitHub
<https://github.com/trilinos/Trilinos/issues/836#issuecomment-260372534>,
or mute the thread
<https://github.com/notifications/unsubscribe-auth/AAjoiWR_riX3gvDBeKksP8kMOiMBWGsGks5q-IMOgaJpZM4KwnIw>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161114/48203435/attachment.html>
