[petsc-dev] strangness in Chebyshev estimate of eigenvalues
    Mark Adams
    mfadams at lbl.gov
    Wed May 25 14:02:12 CDT 2016
> Ok - I've done a 'rebase master' and 'push -f' on mark/snes-ex56c
> You might want to do:
> git checkout mark/snes-ex56c
> git rebase -i 7216b81e99debbb3a0e1c5dd0b26b0d24a8a5ac0
done, but there was nothing in the rebase ("noop").  This is what I see:
noop
# Rebase 7216b81..7216b81 onto 7216b81 (1 command(s))
# Commands:
# p, pick = use commit
# r, reword = use commit, but edit the commit message
# e, edit = use commit, but stop for amending
# s, squash = use commit, but meld into previous commit
# f, fixup = like "squash", but discard this commit's log message
# x, exec = run command (the rest of the line) using shell
# d, drop = remove commit
# These lines can be re-ordered; they are executed from top to bottom.
# If you remove a line here THAT COMMIT WILL BE LOST.
# However, if you remove everything, the rebase will be aborted.
# Note that empty commits are commented out
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160525/a872f468/attachment.html>
