[petsc-dev] BDF implementation
Lisandro Dalcin
dalcinl at gmail.com
Wed Mar 30 10:28:40 CDT 2016
On 30 March 2016 at 17:33, Abhyankar, Shrirang G. <abhyshr at anl.gov> wrote:
> Lisandro,
> I believe only arkimex has restarting currently implemented (see TStep_ARKIMEX). It checks the vector state and uses backward Euler for restarting. Would that the check on the vector state be sufficient or do you think having a flag in postevent callback would be better?
Do you mean the first big block TStep_ARKIMEX, right after
PetscFunctionBegin? Wow, if that works so it is a neat hack. I always
forget about this feature of Vec. Let me investigate it a little bit,
hopefully that is enough! Actually, is likely much better than
complicating the TSEvent API with extra flags.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 4332
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
