[petsc-dev] HDF5 usage in PETSc without MPI? WTF? Totally broken?
Jed Brown
jed at jedbrown.org
Thu Mar 24 05:43:08 CDT 2016
Matthew Knepley <knepley at gmail.com> writes:
> On Wed, Mar 23, 2016 at 2:28 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> Jed and Matt and anyone else who understands the HDF5 viewer
>> No one has answered this. If I get no response I am going to
>> assume that PETSc requires HDF5 built with MPI and remove the #if defs in
>> the code.
> Are you sure that the Vec code fails when HDF5 is serial? I don't know what
> happens when multiple
> procs use H5Lexists() and friends. Maybe its transactional on the file. It
> does use
Each process uses a different filespace, so metadata conflicts would be
the only possible problem. I thought it was working as is, but I don't
use the PETSc HDF5 viewer.
> PetscStackCallHDF5Return(plist_id,H5Pcreate,(H5P_DATASET_XFER));
> #if defined(PETSC_HAVE_H5PSET_FAPL_MPIO)
> PetscStackCallHDF5(H5Pset_dxpl_mpio,(plist_id, H5FD_MPIO_COLLECTIVE));
> #endif
> If it does require MPI, then fine, take out the #ifdefs.
I think that if it doesn't currently work with non-MPI HDF5, it should
be made to work. If anything, that probably means guarding some calls
with if (!rank).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160324/7f5b14d3/attachment.sig>
