[petsc-dev] HDF5 usage in PETSc without MPI? WTF? Totally	broken?
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Mar 23 14:28:27 CDT 2016
  Jed and Matt and anyone else who understands the HDF5 viewer
       No one has answered this. If I get no response  I am going to assume that PETSc requires HDF5 built with MPI and remove the #if defs in the code.
  Barry
> On Mar 18, 2016, at 2:50 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  I am confused about the usage of HDF5 from PETSc.
>   In hdf5.py
>  def configureLibrary(self):
>    if self.libraries.check(self.dlib, 'H5Pset_fapl_mpio'):
>      self.addDefine('HAVE_H5PSET_FAPL_MPIO', 1)
>    return
>  So PETSc does not require HDF5 to have been built using MPI (for example if it was built by someone else without MPI.)
>  In PetscErrorCode  PetscViewerFileSetName_HDF5(PetscViewer viewer, const char name[])
> #if defined(PETSC_HAVE_H5PSET_FAPL_MPIO)
>  PetscStackCallHDF5(H5Pset_fapl_mpio,(plist_id, PetscObjectComm((PetscObject)viewer), info));
> #endif
>  so it only sets collective IO if the symbol was found and hence HDF5 was built for MPI
>  But in places like  VecView_MPI_HDF5(Vec xin, PetscViewer viewer)
>   it uses MPI as if it was collective? Though it might not be because hdf5 could have been built without MPI
>  So if I build PETSc with a non-MPI hdf5 and yet use the hdf5 viewer in parallel; do the generated hdf5 files contain garbage?
>  It seems to me we need to have hdf5.py REQUIRE the existence of H5Pset_fapl_mpio?
>  Barry
