[petsc-dev] mpi/cuda issue
Satish Balay
balay at mcs.anl.gov
Tue Mar 22 16:18:47 CDT 2016
On Tue, 22 Mar 2016, Barry Smith wrote:
> > On Mar 22, 2016, at 1:35 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > An alternative is to have another nightly build with
> > --download-superlu_dist-commit=origin/master. [similary add in other
> > packages that currenlty use origin/master]
> This could be ok. Perhaps have one packages test that uses master for all the external packages possible?
Ok - I switched a copule of packages away from origin/master - and added a build.
https://bitbucket.org/petsc/petsc/commits/fbbed17630f1b121bd29cd1965285e9301f94437
https://bitbucket.org/petsc/petsc/commits/9f44ea2bfc3a26100a4ab82600c98010a0cc1150
Satish
