[petsc-dev] PETSc release soon, request for input on needed fixes or enhancements
Barry Smith
bsmith at mcs.anl.gov
Wed Mar 16 14:40:00 CDT 2016
Thanks. This is definitely a bug, but very different from my understanding of what was reported (which is why one should always tell someone how to reproduce a problem in a bug report). It is because the PushFormat is done regardless of whether it is a new viewer or just the same viewer being set again.
Absolutely needs to be fixed. I don't like the idea of cluttering up the object landscape of PETSc even more by adding new objects such as "viewer plus format" as was suggested.
I need to think about a way to fix this that results in less cluttered code, nor more cluttered code.
Barry
> On Mar 16, 2016, at 2:18 PM, Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> wrote:
> On 16/03/16 18:56, Barry Smith wrote:
>> Please send me a command line option and example (one in the repository?) where this problem happens.
> I had slightly misread the code (MG setup doesn't call
> KSPSetFromOptions more than once even when PCSetUP_MG is called
> again), but here is an example:
> cd src/ts/examples/tutorials
> make ex26
> ./ex26 -da_refine 1 -ts_max_steps 10 -ts_rtol 1e-3 -ts_atol 1e-3
> -ts_type beuler -pc_type asm -pc_asm_blocks 30 -sub_ksp_type
> richardson -sub_ksp_monitor
> Cheers,
> Lawrence
