[petsc-dev] Memory Logging Problem
Sat Mar 12 19:21:36 CST 2016
Suppose
  1) You are using -dll_prepend <lib> to load a dynamic library
  2) Your library is in the stack for a memory leak
  3) You use -malloc_test
Then you get an SEGV because the static pointer to the __FILE__ and
__FUNCT__
in the stack structure are no longer in scope when the malloc log is
printed.
You can fix the SEGV by moving the library unloading to after the malloc
dump. However,
it then records that the memory from loading the library is still unfreed.
We could tell -malloc_test and friends to ignore that memory. Is this what
we should do?
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160312/7a7886d7/attachment.html>
