[petsc-dev] [petsc-checkbuilds] PETSc blame digest (master) 2016-03-10
Thu Mar 10 21:21:33 CST 2016
I pused - what I thought was a clang warnings fix. But I see it broke on windows.
Will check..
Satish
On Thu, 10 Mar 2016, Barry Smith wrote:
>   How'ed this crap and others get into master? Suppose to be clean in next first
> > On Mar 10, 2016, at 9:00 PM, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
> > Dear PETSc developer,
> > This email contains listings of contributions attributed to you by
> > `git blame` that caused compiler errors or warnings in PETSc automated
> > testing.  Follow the links to see the full log files. Please attempt to fix
> > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> > to resolve the issues.
> > Thanks,
> >  The PETSc development team
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/0844979
> > Plex+SNES+TS: Complete reorganization of residual evaluation
> >  src/snes/utils/dmplexsnes.c:1163
> >    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/10/build_master_arch-mswin_ps3.log]
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1163) : warning C4090: 'function' : different 'const' qualifiers
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1163) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >  src/snes/utils/dmplexsnes.c:1165
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1165) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1165) : warning C4090: 'function' : different 'const' qualifiers
> >  src/snes/utils/dmplexsnes.c:1166
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1166) : warning C4090: 'function' : different 'const' qualifiers
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1166) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >  src/snes/utils/dmplexsnes.c:1216
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1216) : warning C4090: 'function' : different 'const' qualifiers
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1216) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >  src/snes/utils/dmplexsnes.c:1217
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1217) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1217) : warning C4090: 'function' : different 'const' qualifiers
> >  src/snes/utils/dmplexsnes.c:1329
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1329) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1329) : warning C4090: 'function' : different 'const' qualifiers
> >  src/snes/utils/dmplexsnes.c:1331
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1331) : warning C4090: 'function' : different 'const' qualifiers
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1331) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >  src/snes/utils/dmplexsnes.c:1332
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1332) : warning C4090: 'function' : different 'const' qualifiers
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1332) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >  src/snes/utils/dmplexsnes.c:1467
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1467) : warning C4090: 'function' : different 'const' qualifiers
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1467) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >  src/snes/utils/dmplexsnes.c:1469
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1469) : warning C4090: 'function' : different 'const' qualifiers
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1469) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >  src/snes/utils/dmplexsnes.c:1495
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1495) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1495) : warning C4090: 'function' : different 'const' qualifiers
> >  src/snes/utils/dmplexsnes.c:1496
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1496) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1496) : warning C4090: 'function' : different 'const' qualifiers
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/113c68e
> > Plex+TS: Now the minimum cell radius is held by the Plex
> >  src/dm/impls/plex/plexgeometry.c:1573
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexgeometry.c(1573) : warning C4090: 'function' : different 'const' qualifiers
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexgeometry.c(1573) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/856ac71
> > Plex: Added DMPlexComputeGradientFVM()
> >  src/dm/impls/plex/plexgeometry.c:1662
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexgeometry.c(1662) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexgeometry.c(1662) : warning C4090: 'function' : different 'const' qualifiers
> >  src/dm/impls/plex/plexgeometry.c:1679
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexgeometry.c(1679) : warning C4090: 'function' : different 'const' qualifiers
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexgeometry.c(1679) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/cca9989
> > SNES+Plex: Fixed FEM face interpolation
> >  src/snes/utils/dmplexsnes.c:1211
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1211) : warning C4022: 'DMPlexPointLocalFieldRead' : pointer mismatch for actual parameter 5
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1211) : warning C4090: 'function' : different 'const' qualifiers
> >  src/snes/utils/dmplexsnes.c:1212
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1212) : warning C4022: 'DMPlexPointLocalFieldRead' : pointer mismatch for actual parameter 5
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\snes\utils\dmplexsnes.c(1212) : warning C4090: 'function' : different 'const' qualifiers
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/d7ddef9
> > Plex: Added DMPlexInsertBoundaryValues()
> >  src/dm/impls/plex/plexfem.c:638
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexfem.c(638) : warning C4090: 'function' : different 'const' qualifiers
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexfem.c(638) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >  src/dm/impls/plex/plexfem.c:647
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexfem.c(647) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexfem.c(647) : warning C4090: 'function' : different 'const' qualifiers
> >  src/dm/impls/plex/plexfem.c:648
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexfem.c(648) : warning C4090: 'function' : different 'const' qualifiers
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexfem.c(648) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >  src/dm/impls/plex/plexfem.c:649
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexfem.c(649) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexfem.c(649) : warning C4090: 'function' : different 'const' qualifiers
> >  src/dm/impls/plex/plexfem.c:658
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexfem.c(658) : warning C4022: 'DMPlexPointLocalRead' : pointer mismatch for actual parameter 4
> >      C:\cygwin\home\sbalay\PETSC~1.CLO\src\dm\impls\plex\plexfem.c(658) : warning C4090: 'function' : different 'const' qualifiers
> > To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
