[petsc-dev] valgrind question
Tue Mar 1 22:27:31 CST 2016
sometimes 'cmake' does a 'strip' during install of the library [which
can delete the debug symbols]. We had to track this down for one of
the cmake packages. I don't remember what we did to workarround it..
petsc at es:/scratch/petsc/petsc/arch-linux-pkgs-valgrind/lib$ file libsuperlu_dist.so.5.0.0
libsuperlu_dist.so.5.0.0: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, not stripped
looks like superlu_dist installed by petsc is not stripped. Perhaps
you can try:
file /home/xiaoye/Dropbox/Codes/SuperLU/superlu_dist.git/lib/libsuperlu_dist.so.5.0.0
Satish
On Tue, 1 Mar 2016, Barry Smith wrote:
>   Satish will know far better than me. I only use Linux when my Mac OS fails me :-(
> > On Mar 1, 2016, at 8:41 PM, Xiaoye S. Li <xsli at lbl.gov> wrote:
> > This is on linux (ubunto).  I did compile with -g, but only the example driver (which is outside library) shows the line number, the routine in the *.so does not show line number, see this:
> > ==31609== Conditional jump or move depends on uninitialised value(s)
> > ==31609==    at 0x51EED86: MPIC_Waitall (in /home/xiaoye/mpich-install/lib/libmpi.so.12.1.0)
> > ==31609==    by 0x5148F99: MPIR_Alltoallv_intra (in /home/xiaoye/mpich-install/lib/libmpi.so.12.1.0)
> > ==31609==    by 0x5149916: MPIR_Alltoallv (in /home/xiaoye/mpich-install/lib/libmpi.so.12.1.0)
> > ==31609==    by 0x51499F6: MPIR_Alltoallv_impl (in /home/xiaoye/mpich-install/lib/libmpi.so.12.1.0)
> > ==31609==    by 0x514A0C7: PMPI_Alltoallv (in /home/xiaoye/mpich-install/lib/libmpi.so.12.1.0)
> > ==31609==    by 0x4E7C56A: pdCompRow_loc_to_CompCol_global (in /home/xiaoye/Dropbox/Codes/SuperLU/superlu_dist.git/lib/libsupe\
> > rlu_dist.so.5.0.0)
> > ==31609==    by 0x4E71761: pdgssvx (in /home/xiaoye/Dropbox/Codes/SuperLU/superlu_dist.git/lib/libsuperlu_dist.so.5.0.0)
> > ==31609==    by 0x401400: main (pddrive.c:171)
> > Here are the flags:
> > C_FLAGS =  -DUSE_VENDOR_BLAS -DAdd_ -DDEBUGlevel=0 -DPRNTlevel=0 -std=c99 -g -fPIC -I/home/xiaoye/Dropbox/Codes/SuperLU/superl\
> > u_dist.git/SRC -I/home/xiaoye/lib/parmetis-4.0.3/include -I/home/xiaoye/lib/parmetis-4.0.3/metis/include -I/home/xiaoye/mpich-\
> > install/include
> > Any idea?
> > Sherry
> > On Tue, Mar 1, 2016 at 6:00 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On Mar 1, 2016, at 7:41 PM, Xiaoye S. Li <xsli at lbl.gov> wrote:
> > > Barry,
> > > I am cleaning up the valgrind errors. I did a build with shared library option, but valgrind doesn't give me the source code line number.  Is it true that I need to build as static library?
> >   No but if you are running on an Apple you may need the additional valgrind option --dsymutil=yes  (yes it is totally goofy that it doesn't just do this automatically). Also, of course, the source code needs be compiled with the -g option.
> >   Barry
> > > Sherry
