[petsc-dev] Could you look at this warning?
Jed Brown jed at jedbrown.org
Tue Mar 1 20:06:32 CST 2016
Barry Smith <bsmith at mcs.anl.gov> writes:
>   It is not clear that Microsoft compilers support this :-(  but it would be a reasonable way to go (with a caste check of course).
Fine, use Petsc64bitInt and define the format characters at the same
place that the name was being checked (a la SCNi64 of inttypes.h).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160302/52ac21e1/attachment.sig>
