[petsc-dev] Matt, this is an annoying BuildSystem feature
Tue Mar 1 14:37:04 CST 2016
On Tue, Mar 1, 2016 at 2:32 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Mar 1, 2016, at 2:24 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Mar 1, 2016 at 2:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   Matt,
> >   It prints that it is looking for the directory, then that it found a
> copy, then that it is cloning the repository.
> >   In reality it actually is looking for the directory, then it is
> cloning the repository, then it found a copy.
> > Here is what happens:
> >   1) The retriever does a clone() and logs into a buffer
> >   2) We call getDir(), which logs the Looking and Found lines,
> > I can have it log Clone, Looking, and Found. Would that be better?
>   I'd just like the order things are presented in the log to match the
> order they were performed (otherwise it is very confusing).
Pushed.
  Matt
>    Barry
> >   Matt
> >   Is there any way to fix the logging so its listed in the order that it
> actually happens?
> >                     Looking for SUPERLU_DIST at git.superlu_dist,
> hg.superlu_dist or a directory starting with SuperLU_DIST
> >                     Found a copy of SUPERLU_DIST in git.superlu_dist
> > Executing: git clone https://github.com/xiaoyeli/superlu_dist
> /export/home/petsc/petsc.clone/arch-opensolaris-pkgs-opt/externalpackages/git.superlu_dist
> > stdout: Cloning into
> /export/home/petsc/petsc.clone/arch-opensolaris-pkgs-opt/externalpackages/git.superlu_dist...
> > Executing: ['git', 'fetch']
> > Executing: ['git', 'rev-parse', 'origin/master']
> > stdout: 35c3b21630d93b3f8392a68e607467c247b5e053
> > Executing: ['git', 'stash']
> > stdout: No local changes to save
> > Executing: ['git', 'checkout', '-f',
> '35c3b21630d93b3f8392a68e607467c247b5e053']
> >                         Pushing language C
> >                         Popping language C
> >                         Pushing language Cxx
> >                         Popping language Cxx
> >                         Pushing language FC
> >                         Popping language FC
> > Have to rebuild SUPERLU_DIST,
> /export/home/petsc/petsc.clone/arch-opensolaris-pkgs-opt/externalpackages/git.superlu_dist/superlu_dist.petscconf
> /export/home/petsc/petsc.clone/arch-opensolaris-pkgs-opt/lib/petsc/conf/pkg.conf.superlu_dist
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160301/2d8211eb/attachment.html>
