[petsc-dev] Matt, this is an annoying BuildSystem feature
Barry Smith
bsmith at mcs.anl.gov
Tue Mar 1 14:13:52 CST 2016
Matt,
It prints that it is looking for the directory, then that it found a copy, then that it is cloning the repository.
In reality it actually is looking for the directory, then it is cloning the repository, then it found a copy.
Is there any way to fix the logging so its listed in the order that it actually happens?
Looking for SUPERLU_DIST at git.superlu_dist, hg.superlu_dist or a directory starting with SuperLU_DIST
Found a copy of SUPERLU_DIST in git.superlu_dist
Executing: git clone https://github.com/xiaoyeli/superlu_dist /export/home/petsc/petsc.clone/arch-opensolaris-pkgs-opt/externalpackages/git.superlu_dist
stdout: Cloning into /export/home/petsc/petsc.clone/arch-opensolaris-pkgs-opt/externalpackages/git.superlu_dist...
Executing: ['git', 'fetch']
Executing: ['git', 'rev-parse', 'origin/master']
stdout: 35c3b21630d93b3f8392a68e607467c247b5e053
Executing: ['git', 'stash']
stdout: No local changes to save
Executing: ['git', 'checkout', '-f', '35c3b21630d93b3f8392a68e607467c247b5e053']
Pushing language C
Popping language C
Pushing language Cxx
Popping language Cxx
Pushing language FC
Popping language FC
Have to rebuild SUPERLU_DIST, /export/home/petsc/petsc.clone/arch-opensolaris-pkgs-opt/externalpackages/git.superlu_dist/superlu_dist.petscconf != /export/home/petsc/petsc.clone/arch-opensolaris-pkgs-opt/lib/petsc/conf/pkg.conf.superlu_dist
