[petsc-dev] Ghost update in VecAssembly?
Jed Brown
jed at jedbrown.org
Tue Mar 1 10:36:22 CST 2016
Matthew Knepley <knepley at gmail.com> writes:
>> > I was confusing the VecGhostUpdate() above which puts local values in the
>> > global vector
>> > with the update which would refresh the local portion. The former update
>> > should be called
>> > automatically during assembly, which already happens in the
>> > FormFunctionLocals,
>> Uh, no, and they don't use VecGhost...
> Yes, it most certainly does happen when FormFunctionLocal is
> used. PETSc calls Assembly, at least in the Plex variant. Of course,
> they do not use VecGhost.
SNESComputeFunction_DMDA:
switch (dmdasnes->residuallocalimode) {
case INSERT_VALUES: {
ierr = DMDAVecGetArray(dm,F,&f);CHKERRQ(ierr);
ierr = PetscLogEventBegin(SNES_FunctionEval,snes,X,F,0);CHKERRQ(ierr);
CHKMEMQ;
ierr = (*dmdasnes->residuallocal)(&info,x,f,dmdasnes->residuallocalctx);CHKERRQ(ierr);
CHKMEMQ;
ierr = PetscLogEventEnd(SNES_FunctionEval,snes,X,F,0);CHKERRQ(ierr);
ierr = DMDAVecRestoreArray(dm,F,&f);CHKERRQ(ierr);
} break;
case ADD_VALUES: {
Vec Floc;
ierr = DMGetLocalVector(dm,&Floc);CHKERRQ(ierr);
ierr = VecZeroEntries(Floc);CHKERRQ(ierr);
ierr = DMDAVecGetArray(dm,Floc,&f);CHKERRQ(ierr);
CHKMEMQ;
CHKMEMQ;
ierr = DMDAVecRestoreArray(dm,Floc,&f);CHKERRQ(ierr);
ierr = VecZeroEntries(F);CHKERRQ(ierr);
ierr = DMLocalToGlobalBegin(dm,Floc,ADD_VALUES,F);CHKERRQ(ierr);
ierr = DMLocalToGlobalEnd(dm,Floc,ADD_VALUES,F);CHKERRQ(ierr);
ierr = DMRestoreLocalVector(dm,&Floc);CHKERRQ(ierr);
} break;
See how this uses DMLocalToGlobal and there is no VecAssembly.
src/snes/utils/dmplexsnes.c is far more confusing, but still contains no
VecAssembly.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160301/7501138c/attachment.sig>
