[petsc-dev] Ghost update in VecAssembly?
Tue Mar 1 09:28:45 CST 2016
On Tue, Mar 1, 2016 at 8:56 AM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> No.  You only need to call VecAssembly if you use VecSetValues.  But if
> > I thought we had state increase on getarray() as well, but its just
> locking.
> VecRestoreArray calls PetscObjectStateIncrease, but what does that has
> to do with VecAssembly?
> >> you have a ghosted vector, you would normally use VecGetArray and never
> >> bother with VecSetValues.
> > Why would we assume people make the ghost values as well?
> Huh?
> > However, if this is the only case, I don't think putting it in is a
> > great idea.
I am trying to understand what you are saying here. I have a vector on 2
procs, divided as
p0  |----interior---|--ghost--|
p1  |----interior---|--ghost--|
Now I calculate some values in the interior on both procs using
VecGetArray(),
p0  |xxxxinteriorxxx|--ghost--|
p1  |xxxxinteriorxxx|--ghost--|
What is wrong with calling VecGhostUpdate() here to fill in the ghosts? Is
your contention
that I should have also calculated the ghosts?
  Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160301/d52f5761/attachment.html>
