[petsc-dev] Ghost update in VecAssembly?
    Matthew Knepley
    knepley at gmail.com
    Tue Mar  1 08:41:08 CST 2016
On Tue, Mar 1, 2016 at 8:23 AM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> ghost values.  Also, who uses VecGhost _and_ VecAssembly for the same
> >> Vec?  That's quite wasteful; if you have local indexing, why not just
> >> use VecGhostUpdate(...,SCATTER_REVERSE)?
> > I do not understand this argument. If you form the local part of each
> vector
> > using VecGetArray(), then you must call both VecAssembly()
> No.  You only need to call VecAssembly if you use VecSetValues.  But if
I thought we had state increase on getarray() as well, but its just locking.
> you have a ghosted vector, you would normally use VecGetArray and never
> bother with VecSetValues.
Why would we assume people make the ghost values as well? However, if this
is the only case, I don't think putting it in is a great idea.
  Matt
> > and VecGhostUpdate(), which I think is the complaint.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160301/3d26394f/attachment.html>
