[petsc-dev] memory usage with GPUs
    Karl Rupp
    rupp at iue.tuwien.ac.at
    Fri Jul 29 11:58:03 CDT 2016
>        Do you know if Nvidia provides an API to determine how much GPU
>     memory has been currently allocated?
> Yes it does
The information is readily available through the nvidia-smi command line
tool.
Is there a good reason for providing the total allocated memory on GPUs
(including non-PETSc memory) through PETSc? If so, why don't we already
print the total system memory usage?
Best regards,
Karli
