[petsc-dev] memory usage with GPUs
Mark Adams mfadams at lbl.gov
Wed Jul 27 20:18:52 CDT 2016
Note, I wanted to use this for a Petsc code  that uses GPUs but not through
at Petsc.
So my case is a little odd and I did not expect support but I just wanted
to check.
On Wednesday, July 27, 2016, Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
>    We (meanings someone) should add logging of GPU allocations separately.
> Agreed. I'll do it (though not immediately, as there are other things with
> higher priority to make GPU support in PETSc more useful)
> Best regards,
> Karli
>> On Jul 27, 2016, at 1:41 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> No, although since we mirror storage you could get an idea if you broke
>>> out the GPU vecs into a separate stage.
>>>     Matt
>>> On Wed, Jul 27, 2016 at 9:05 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> Would/could PETSc memory usage methods (PetscMemoryGetMaximumUsage) pick
>>> up GPU memory usage?
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160727/749cee6e/attachment.html>
