[petsc-dev] Algebraic Multigrid
Mark Adams mfadams at lbl.gov
Wed Jul 27 16:26:03 CDT 2016
Please keep this on the Petsc list.
We seem to have lost Jacobi smoother again. I'm suspecting that you're some
funny character in your line with Jacobi  that is Confusing the parser. Get
back to the old file with the two two Jacobi entries and delete the other
line and get Jacobi in the KSP view output. There should be no SOR in the
output.
On Wednesday, July 27, 2016, Ari Rappaport <arir at vosssci.com> wrote:
> Hi Mark,
> I added all these new things. The PCAMG is now ending very quickly but the
> residual is unreasonably large by about 10 orders of magnitude. I noticed
> the line "Linear solve did not converge due to DIVERGED_INDEFINITE_PC
> iterations 2" in the output, could this be causing the problem? It only
> appears to be going for 2 iterations now.
> -Ari
> From: "Mark Adams" <mfadams at lbl.gov <javascript:;>>
> To: "Ari Rappaport" <arir at vosssci.com <javascript:;>>
> Cc: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov
> <javascript:;>>
> Sent: Tuesday, July 26, 2016 5:07:34 PM
> Subject: Re: [petsc-dev] Algebraic Multigrid
> Ari, I would also check that your operator is not messed up in parallel.
> The solver is looking pretty solid.
> Also, you can configure PETSc with hypre and use '-pc_type hypre'. If
> hypre is also good in serial but hosed on multi-proc then it is most
> probably your operator.
> On Tue, Jul 26, 2016 at 6:58 PM, Mark Adams < mfadams at lbl.gov
> <javascript:;> > wrote:
> So remove one of the -mg_levels_pc_type jacobi and add -mg_coarse_ksp_type
> preonly, then verify that this works on one proc and then try two procs.
> On Tue, Jul 26, 2016 at 6:56 PM, Mark Adams < mfadams at lbl.gov
> Oh, actually this worked. You have this ...pc_type jacobi in there twice,
> so one of them was "unused".
> Try this with 2 processors now.
> On Tue, Jul 26, 2016 at 6:42 PM, Mark Adams < mfadams at lbl.gov
> On Tue, Jul 26, 2016 at 6:24 PM, Ari Rappaport < arir at vosssci.com
> So I commented out the line PCSetType(pc, PCGAMG). The line
> KSPSetFromOptions(ksp) was already in the code at the end of our
> initialization routine. I also added .petscrc to the working dir. Here is
> the current output. It seems as if Option left: name:-mg_levels_pc_type
> jacobi (no value) is still present in the output..I dunno.
> Yea, I dunno either. If you use -help you will get printout of the
> available options. If you do this you will see stuff like -mg_levels_1_ ...
> you can also see this in the ksp_view. There is a shortcut that lets you
> _not_ put "_1" in. Try putting this in for each level like so:
> -mg_levels_1_pc_type jacobi
> -mg_levels_2_pc_type jacobi
> -mg_levels_3_pc_type jacobi
> I also notice that the coarse grid ksp is GMRES. This is our fault. It
> should be preonly. Add:
> -mg_coarse_ksp_type preonly
> -Ari
> From: "Mark Adams" < mfadams at lbl.gov <javascript:;> >
> To: "Ari Rappaport" < arir at vosssci.com <javascript:;> >, "For users of
> the development version of PETSc" < petsc-dev at mcs.anl.gov <javascript:;> >
> Sent: Tuesday, July 26, 2016 4:03:03 PM
> At the end of this you have:
> #PETSc Option Table entries:
> -ksp_view
> -options_left
> #End of PETSc Option Table entries
> There is one unused database option. It is:
> Option left: name:-mg_levels_pc_type jacobi (no value)
> So this jacobi parameter is not being used.
> Do you call KPSSetFromOptions? Do you set solver parameters in the code?
> Like PCGAMG?
> You should not set anything in the code, it just confuses things at this
> point. Use KSPSetFromOptions(). You can hardwire stuff before this call,
> this just lets you set the defaults, but you should always call this last
> to let command line parameters override the defaults.
> You can put this in a .petscrc file in the working directory and try again.
> -ksp_type cg
> -ksp_max_it 50
> -ksp_rtol 1.e-6
> -ksp_converged_reason
> -pc_type gamg
> -pc_gamg_type agg
> -pc_gamg_agg_nsmooths 1
> -pc_gamg_coarse_eq_limit 10
> -pc_gamg_reuse_interpolation true
> -pc_gamg_square_graph 1
> -pc_gamg_threshold -0.05
> -mg_levels_ksp_max_it 2
> -mg_levels_ksp_type chebyshev
> -mg_levels_esteig_ksp_type cg
> -mg_levels_esteig_ksp_max_it 10
> -mg_levels_ksp_chebyshev_esteig 0,.05,0,1.05
> -pc_hypre_type boomeramg
> -pc_hypre_boomeramg_no_CF
> -pc_hypre_boomeramg_agg_nl 1
> -pc_hypre_boomeramg_coarsen_type HMIS
> -pc_hypre_boomeramg_interp_type ext+i
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160727/3ee8fce1/attachment.html>
