[petsc-dev] Algebraic Multigrid
    Mark Adams
    mfadams at lbl.gov
    Tue Jul 26 17:56:18 CDT 2016
Oh, actually this worked.  You have this ...pc_type jacobi in there twice,
so one of them was "unused".
Try this with 2 processors now.
On Tue, Jul 26, 2016 at 6:42 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Tue, Jul 26, 2016 at 6:24 PM, Ari Rappaport <arir at vosssci.com> wrote:
>> So I commented out the line PCSetType(pc, PCGAMG). The line
>> KSPSetFromOptions(ksp) was already in the code at the end of our
>> initialization routine. I also added .petscrc to the working dir. Here is
>> the current output. It seems as if Option left: name:-mg_levels_pc_type
>> jacobi (no value) is still present in the output..I dunno.
> Yea, I dunno either.  If you use -help you will get printout of the
> available options.  If you do this you will see stuff like -mg_levels_1_
> ... you can also see this in the ksp_view.  There is a shortcut that lets
> you _not_ put "_1" in.  Try putting this in for each level like so:
> -mg_levels_1_pc_type jacobi
> -mg_levels_2_pc_type jacobi
> -mg_levels_3_pc_type jacobi
> I also notice that the coarse grid ksp is GMRES.  This is our fault.  It
> should be preonly. Add:
> -mg_coarse_ksp_type preonly
>> -Ari
>> ----- Original Message -----
>> From: "Mark Adams" <mfadams at lbl.gov>
>> To: "Ari Rappaport" <arir at vosssci.com>, "For users of the development
>> version of PETSc" <petsc-dev at mcs.anl.gov>
>> Sent: Tuesday, July 26, 2016 4:03:03 PM
>> Subject: Re: [petsc-dev] Algebraic Multigrid
>> At the end of this you have:
>> #PETSc Option Table entries:
>> -ksp_view
>> -mg_levels_pc_type jacobi
>> -options_left
>> #End of PETSc Option Table entries
>> There is one unused database option. It is:
>> Option left: name:-mg_levels_pc_type jacobi (no value)
>> So this jacobi parameter is not being used.
>> Do you call KPSSetFromOptions? Do you set solver parameters in the code?
>> Like PCGAMG?
>> You should not set anything in the code, it just confuses things at this
>> point. Use KSPSetFromOptions(). You can hardwire stuff before this call,
>> this just lets you set the defaults, but you should always call this last
>> to let command line parameters override the defaults.
>> You can put this in a .petscrc file in the working directory and try
>> again.
>> -ksp_type cg
>> -ksp_max_it 50
>> -ksp_rtol 1.e-6
>> -ksp_converged_reason
>> -pc_type gamg
>> -pc_gamg_type agg
>> -pc_gamg_agg_nsmooths 1
>> -pc_gamg_coarse_eq_limit 10
>> -pc_gamg_reuse_interpolation true
>> -pc_gamg_square_graph 1
>> -pc_gamg_threshold -0.05
>> -mg_levels_ksp_max_it 2
>> -mg_levels_ksp_type chebyshev
>> -mg_levels_esteig_ksp_type cg
>> -mg_levels_esteig_ksp_max_it 10
>> -mg_levels_ksp_chebyshev_esteig 0,.05,0,1.05
>> -pc_hypre_type boomeramg
>> -pc_hypre_boomeramg_no_CF
>> -pc_hypre_boomeramg_agg_nl 1
>> -pc_hypre_boomeramg_coarsen_type HMIS
>> -pc_hypre_boomeramg_interp_type ext+i
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160726/52ae7f55/attachment.html>
