[petsc-dev] Fortran interfaces for VecGetLocalVector and VecRestoreLocalVector
Mon Jul 18 14:19:33 CDT 2016
pushed this fix to maint.
Satish
On Mon, 18 Jul 2016, Satish Balay wrote:
> yes -  these 2 functions can have fortran stubs autogenerated.
> Removing the 'C' - and then running configure [which does an
> equivalent of 'make allfortranstubs'] - and 'make all' would be the
> steps..
> Satih
> On Mon, 18 Jul 2016, Patrick Sanan wrote:
> > I'd like to use VecGetLocalVector and VecRestoreLocalVector from Fortran.
> > It appears that these are not covered by the Fortran interface, based
> > on the fact that they don't appear in my include/petsc/finclude
> > directory anywhere, even though other related functions do.
> > This seems to be confirmed by the fact that this function has the
> > "comment-only" Sowing block in src/vec/vec/interface/rvector.c and
> > does not appear in the ftn-custom (or f90-custom) directory there.
> > I'm new to using Fortran directly with PETSc.  I can delete the "C"
> > from the Sowing blocks, rebuild the library, and link, but I'm not
> > confident enough to say that this worked yet. Should that be all that
> > is required to make these functions available?
