[petsc-dev] p4est configure error
Mark Adams
mfadams at lbl.gov
Fri Jul 8 07:23:17 CDT 2016
As I said, I need two passes to get this to work, here is the first
(failed) configure on Cori. With any luck my current configure will work
and I can send that along.
Note, this used to work on Edison, so it might be something not worth, or
even possible, to fix with NERSC's help.
On Thu, Jul 7, 2016 at 9:12 PM, Tobin Isaac <tisaac at uchicago.edu> wrote:
> I'd be happy to help some more if you send a successful log from Cori.
> On July 7, 2016 7:18:30 PM CDT, Mark Adams <mfadams at lbl.gov> wrote:
> >Yes, if fails on debug=0. This used to work on Edison and it does work
> >now
> >on Cori.
> >On Fri, Jul 8, 2016 at 1:07 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >> whoops, that did not have p4est
> >> On Fri, Jul 8, 2016 at 1:04 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >>> On Fri, Jul 8, 2016 at 12:18 AM, Tobin Isaac <tisaac at uchicago.edu>
> >wrote:
> >>>> Interesting, you'd think that --disable-shared would be all that
> >>>> matters. Could you please send that configure.log for comparison?
> >>>> On July 7, 2016 5:14:13 PM CDT, Mark Adams <mfadams at lbl.gov> wrote:
> >>>> >Well, this did not work as you suspected ... FYI, it seems to work
> >>>> >with-debugging=0.
> >>>> >On Thu, Jul 7, 2016 at 11:13 PM, Satish Balay <balay at mcs.anl.gov>
> >>>> >wrote:
> >>>> >> /bin/sh ./libtool --tag=CC --mode=link cc -no-ipo -g -O0
> >-o
> >>>> >> libb64/sc_b64enc libb64/libb64_sc_b64enc-b64enc.o ./src/libsc.la
> >>>> >-lgomp
> >>>> >> libtool: link: cc -no-ipo -g -O0 -o libb64/sc_b64enc
> >>>> >> libb64/libb64_sc_b64enc-b64enc.o ./src/.libs/libsc.a
> >>>> >> /opt/gcc/5.2.0/snos/lib/../lib64/libgomp.so -lrt -ldl -Wl,-rpath
> >>>> >> -Wl,/opt/gcc/5.2.0/snos/lib/../lib64 -Wl,-rpath
> >>>> >> For some reason libtool is converting "-lgomp" into
> >>>> >> "/opt/gcc/5.2.0/snos/lib/../lib64/libgomp.so" - and giving an ld
> >>>> >error.
> >>>> >> On my linux box - I see:
> >>>> >> /bin/sh ./libtool --tag=CC --mode=link mpicc -g3 -o
> >>>> >libb64/sc_b64enc
> >>>> >> libb64/libb64_sc_b64enc-b64enc.o ./src/libsc.la -lgomp -lpthread
> >-lz
> >>>> >-lm
> >>>> >> libtool: link: mpicc -g3 -o libb64/sc_b64enc
> >>>> >> libb64/libb64_sc_b64enc-b64enc.o ./src/.libs/libsc.a -lgomp
> >>>> >-lpthread -lz
> >>>> >> -lm
> >>>> >> I don't really understand libtool - or this error..
> >>>> >> Satish
> >>>> >> On Thu, 7 Jul 2016, Tobin Isaac wrote:
> >>>> >> > Nope, different error: p4est autotools found an openmp library
> >and
> >>>> >tried
> >>>> >> to link it, but there's a shared/static mismatch. I'll try to
> >get to
> >>>> >the
> >>>> >> bottom of this.
> >>>> >> > On July 7, 2016 3:27:23 PM CDT, Mark Adams <mfadams at lbl.gov>
> >wrote:
> >>>> >> > >I nuked and ran this twice:
> >>>> >> > >1013 rm -fr arch-xc30-dbg64-intel
> >>>> >> > > 1014 ../arch-xc30-dbg64-intel.py
> >>>> >> > > 1015 h
> >>>> >> > > 1016 ../arch-xc30-dbg64-intel.py
> >>>> >> > >Same error.
> >>>> >> > >On Thu, Jul 7, 2016 at 9:36 PM, Satish Balay
> >>>> >wrote:
> >>>> >> > >> perhaps configure was not rerun - so a stale p4est was
> >being
> >>>> >used..
> >>>> >> > >> Satish
> >>>> >> > >> > p4est.py automatically pulls from whatever p4est branch I
> >call
> >>>> >> > >'petsc'
> >>>> >> > >> > in my repo, so I don't see how this problem persists if
> >you
> >>>> >really
> >>>> >> > >> > nuked it.
> >>>> >> > >> > - Did you nuke the right directory?
> >>>> >> > >> > - Did you send me the right configure.log?
> >>>> >> > >> > - Is the new failure the same (the same stale p4est
> >commit is
> >>>> >being
> >>>> >> > >> > used)?
> >>>> >> > >> > On Thu, Jul 07, 2016 at 08:33:57PM +0200, Mark Adams
> >wrote:
> >>>> >> > >> > > It sounds like I have not merged your fix. Should I
> >pull
> >>>> >from
> >>>> >> > >master?
> >>>> >> > >> > > I have nuked this many times.
> >>>> >> > >> > > On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac
> >>>> >> > >> wrote:
> >>>> >> > >> > > > On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams
> >>>> >wrote:
> >>>> >> > >> > > > > p4est on Edison configures in w/o debugging,
> >although I
> >>>> >have
> >>>> >> > >to run
> >>>> >> > >> > > > > configure twice.
> >>>> >> > >> > > > > But with debugging it fails. I can not see any
> >>>> >difference
> >>>> >> > >between
> >>>> >> > >> the
> >>>> >> > >> > > > two
> >>>> >> > >> > > > > configures other than debugging.
> >>>> >> > >> > > > > Mark
> >>>> >> > >> > > > The log shows that you are configuring a p4est commit
> >>>> >(3d3e1)
> >>>> >> > >that is
> >>>> >> > >> > > > before the one I pushed specifically to avoid the
> >fortran
> >>>> >> > >> > > > configuration error (f54bb3). Please clear the
> >git.p4est
> >>>> >> > >directory,
> >>>> >> > >> > > > and confirm that you are configuring with the current
> >>>> >'petsc'
> >>>> >> > >branch
> >>>> >> > >> > > > of p4est (`grep 'checking Point version'
> >configure.log`
> >>>> >should
> >>>> >> > >show
> >>>> >> > >> > > > X.XXX-a9f22).
> >>>> >> > >> > > > Cheers,
> >>>> >> > >> > > > Toby
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160708/ee7ab0fb/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160708/ee7ab0fb/attachment.obj>
