[petsc-dev] p4est configure error
Mark Adams
mfadams at lbl.gov
Thu Jul 7 19:18:30 CDT 2016
Yes, if fails on debug=0. This used to work on Edison and it does work now
on Cori.
On Fri, Jul 8, 2016 at 1:07 AM, Mark Adams <mfadams at lbl.gov> wrote:
> whoops, that did not have p4est
> On Fri, Jul 8, 2016 at 1:04 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> On Fri, Jul 8, 2016 at 12:18 AM, Tobin Isaac <tisaac at uchicago.edu> wrote:
>>> Interesting, you'd think that --disable-shared would be all that
>>> matters. Could you please send that configure.log for comparison?
>>> On July 7, 2016 5:14:13 PM CDT, Mark Adams <mfadams at lbl.gov> wrote:
>>> >Well, this did not work as you suspected ... FYI, it seems to work
>>> >with-debugging=0.
>>> >On Thu, Jul 7, 2016 at 11:13 PM, Satish Balay <balay at mcs.anl.gov>
>>> >wrote:
>>> >> /bin/sh ./libtool --tag=CC --mode=link cc -no-ipo -g -O0 -o
>>> >> libb64/sc_b64enc libb64/libb64_sc_b64enc-b64enc.o ./src/libsc.la
>>> >-lgomp
>>> >> libtool: link: cc -no-ipo -g -O0 -o libb64/sc_b64enc
>>> >> libb64/libb64_sc_b64enc-b64enc.o ./src/.libs/libsc.a
>>> >> /opt/gcc/5.2.0/snos/lib/../lib64/libgomp.so -lrt -ldl -Wl,-rpath
>>> >> -Wl,/opt/gcc/5.2.0/snos/lib/../lib64 -Wl,-rpath
>>> >> For some reason libtool is converting "-lgomp" into
>>> >> "/opt/gcc/5.2.0/snos/lib/../lib64/libgomp.so" - and giving an ld
>>> >error.
>>> >> On my linux box - I see:
>>> >> /bin/sh ./libtool --tag=CC --mode=link mpicc -g3 -o
>>> >libb64/sc_b64enc
>>> >> libb64/libb64_sc_b64enc-b64enc.o ./src/libsc.la -lgomp -lpthread -lz
>>> >-lm
>>> >> libtool: link: mpicc -g3 -o libb64/sc_b64enc
>>> >> libb64/libb64_sc_b64enc-b64enc.o ./src/.libs/libsc.a -lgomp
>>> >-lpthread -lz
>>> >> -lm
>>> >> I don't really understand libtool - or this error..
>>> >> Satish
>>> >> On Thu, 7 Jul 2016, Tobin Isaac wrote:
>>> >> > Nope, different error: p4est autotools found an openmp library and
>>> >tried
>>> >> to link it, but there's a shared/static mismatch. I'll try to get to
>>> >the
>>> >> bottom of this.
>>> >> > On July 7, 2016 3:27:23 PM CDT, Mark Adams <mfadams at lbl.gov> wrote:
>>> >> > >I nuked and ran this twice:
>>> >> > >1013 rm -fr arch-xc30-dbg64-intel
>>> >> > > 1014 ../arch-xc30-dbg64-intel.py
>>> >> > > 1015 h
>>> >> > > 1016 ../arch-xc30-dbg64-intel.py
>>> >> > >Same error.
>>> >> > >On Thu, Jul 7, 2016 at 9:36 PM, Satish Balay <balay at mcs.anl.gov>
>>> >wrote:
>>> >> > >> perhaps configure was not rerun - so a stale p4est was being
>>> >used..
>>> >> > >> Satish
>>> >> > >> > p4est.py automatically pulls from whatever p4est branch I call
>>> >> > >'petsc'
>>> >> > >> > in my repo, so I don't see how this problem persists if you
>>> >really
>>> >> > >> > nuked it.
>>> >> > >> > - Did you nuke the right directory?
>>> >> > >> > - Did you send me the right configure.log?
>>> >> > >> > - Is the new failure the same (the same stale p4est commit is
>>> >being
>>> >> > >> > used)?
>>> >> > >> > On Thu, Jul 07, 2016 at 08:33:57PM +0200, Mark Adams wrote:
>>> >> > >> > > It sounds like I have not merged your fix. Should I pull
>>> >from
>>> >> > >master?
>>> >> > >> > > I have nuked this many times.
>>> >> > >> > > On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac
>>> >> > >> wrote:
>>> >> > >> > > > On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams
>>> >wrote:
>>> >> > >> > > > > p4est on Edison configures in w/o debugging, although I
>>> >have
>>> >> > >to run
>>> >> > >> > > > > configure twice.
>>> >> > >> > > > > But with debugging it fails. I can not see any
>>> >difference
>>> >> > >between
>>> >> > >> the
>>> >> > >> > > > two
>>> >> > >> > > > > configures other than debugging.
>>> >> > >> > > > > Mark
>>> >> > >> > > > The log shows that you are configuring a p4est commit
>>> >(3d3e1)
>>> >> > >that is
>>> >> > >> > > > before the one I pushed specifically to avoid the fortran
>>> >> > >> > > > configuration error (f54bb3). Please clear the git.p4est
>>> >> > >directory,
>>> >> > >> > > > and confirm that you are configuring with the current
>>> >'petsc'
>>> >> > >branch
>>> >> > >> > > > of p4est (`grep 'checking Point version' configure.log`
>>> >should
>>> >> > >show
>>> >> > >> > > > X.XXX-a9f22).
>>> >> > >> > > > Cheers,
>>> >> > >> > > > Toby
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160708/f8e0ac06/attachment.html>
