[petsc-dev] p4est configure error
Tobin Isaac tisaac at uchicago.edu
Thu Jul 7 14:21:13 CDT 2016
p4est.py automatically pulls from whatever p4est branch I call 'petsc'
in my repo, so I don't see how this problem persists if you really
nuked it.
- Did you nuke the right directory?
- Did you send me the right configure.log?
- Is the new failure the same (the same stale p4est commit is being
  used)?
On Thu, Jul 07, 2016 at 08:33:57PM +0200, Mark Adams wrote:
> It sounds like I have not merged your fix.  Should I pull from master?
> I have nuked this many times.
> On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac <tisaac at uchicago.edu> wrote:
> > On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams wrote:
> > > p4est on Edison configures in w/o debugging, although I have to run
> > > configure twice.
> > > But with debugging it fails.  I can not see any difference between the
> > two
> > > configures other than debugging.
> > > Mark
> > The log shows that you are configuring a p4est commit (3d3e1) that is
> > before the one I pushed specifically to avoid the fortran
> > configuration error (f54bb3).  Please clear the git.p4est directory,
> > and confirm that you are configuring with the current 'petsc' branch
> > of p4est (`grep 'checking Point version' configure.log` should show
> > X.XXX-a9f22).
> > Cheers,
> >   Toby
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160707/41af833b/attachment.sig>
