[petsc-dev] asm / gasm
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Jul  3 11:50:02 CDT 2016
  Here is the problem:
        if (!sz) {
          IS       nis;
          ierr = ISCreateGeneral(PETSC_COMM_SELF, 0, NULL, PETSC_COPY_VALUES, &nis);CHKERRQ(ierr);
          ierr = PCASMSetLocalSubdomains(subpc, 1, NULL, &nis);CHKERRQ(ierr);
          ierr = ISDestroy(&nis);CHKERRQ(ierr);
It was setting the first IS when it should be setting the second. When I run after this change I get reasonable results.
 0 KSP Residual norm 2.469493285658e+02
  1 KSP Residual norm 1.335901394170e+01
  2 KSP Residual norm 5.623002716761e-01
  3 KSP Residual norm 5.201650164984e-02
  4 KSP Residual norm 3.763050190737e-03
  5 KSP Residual norm 3.024410926322e-04
Linear solve converged due to CONVERGED_RTOL iterations 5
  0 KSP Residual norm 2.469493285658e-03
  1 KSP Residual norm 1.335901394170e-04
  2 KSP Residual norm 5.623002716761e-06
  3 KSP Residual norm 5.201650164983e-07
  4 KSP Residual norm 3.763050190737e-08
  5 KSP Residual norm 3.024410926322e-09
  0 KSP Residual norm 2.469493285658e-08
  1 KSP Residual norm 1.335901394170e-09
  2 KSP Residual norm 5.623002716761e-11
  3 KSP Residual norm 5.201650164984e-12
  4 KSP Residual norm 3.763050190737e-13
  5 KSP Residual norm 3.024410926322e-14
> On Jul 3, 2016, at 10:40 AM, Mark Adams <mfadams at lbl.gov> wrote:
> Barry,
> GAMG must be setting up the ASM incorrectly, on empty processors, when using the aggregates.  In asm.c, I see that osm->is_local is NULL for empty processors, and this causes a problem when this branch is taken by less than 8 processes (of 8):
>       if (osm->is_local) { // asm.c:282
>         ierr = VecScatterCreate(vec,osm->is_local[i],osm->y_local[i],isl,&osm->prolongation[i]);CHKERRQ(ierr);
> I get an error "MPI_Allreduce() called in different locations (code lines) on different processors ", because "vec" here is global. This gamg.c code must not be correct:
>         if (!sz) {
>           IS       is;
>           ierr = ISCreateGeneral(PETSC_COMM_SELF, 0, NULL, PETSC_COPY_VALUES, &is);CHKERRQ(ierr);
>           ierr = PCASMSetLocalSubdomains(subpc, 1, &is, NULL);CHKERRQ(ierr);
>           ierr = ISDestroy(&is);CHKERRQ(ierr);
>         } else {
> I will look into why osm->is_local seems to be NULL here when it should have an empty IS.
> Mark
