[petsc-dev] asm / gasm
Barry Smith
bsmith at mcs.anl.gov
Sun Jul 3 11:17:04 CDT 2016
Mark,
When I try to run your example in your branch with one process I get the error below; why is that if you do not get the error?
~/Src/petsc/src/snes/examples/tutorials (mark/fix-gamg-asm-aggs=) arch-basic
$ ./ex56 -ne 3 -alpha 1.e-3 -ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 10 -pc_gamg_reuse_interpolation true -two_solves true -ksp_converged_reason -use_mat_nearnullspace -mg_levels_esteig_ksp_type cg -pc_gamg_square_graph 1 -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -gamg_est_ksp_type cg -gamg_est_ksp_max_it 20 -pc_gamg_asm_use_agg -mg_levels_sub_pc_type lu -ksp_monitor -mat_block_size 3
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: !(matA_1 && !matA_1->compressedrow.use)
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.2-757-g1d88083 GIT Date: 2016-06-28 21:49:49 -0500
[0]PETSC ERROR: ./ex56 on a arch-basic named Barrys-MacBook-Pro.local by barrysmith Sun Jul 3 11:15:36 2016
[0]PETSC ERROR: Configure options --download-metis --download-parmetis --with-mpi-dir=/Users/barrysmith/libraries PETSC_ARCH=arch-basic
[0]PETSC ERROR: #1 smoothAggs() line 333 in /Users/barrysmith/Src/petsc/src/ksp/pc/impls/gamg/agg.c
[0]PETSC ERROR: #2 PCGAMGCoarsen_AGG() line 1001 in /Users/barrysmith/Src/petsc/src/ksp/pc/impls/gamg/agg.c
[0]PETSC ERROR: #3 PCSetUp_GAMG() line 524 in /Users/barrysmith/Src/petsc/src/ksp/pc/impls/gamg/gamg.c
[0]PETSC ERROR: #4 PCSetUp() line 968 in /Users/barrysmith/Src/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #5 KSPSetUp() line 393 in /Users/barrysmith/Src/petsc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #6 main() line 384 in /Users/barrysmith/Src/petsc/src/snes/examples/tutorials/ex56.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -alpha 1.e-3
[0]PETSC ERROR: -gamg_est_ksp_max_it 20
[0]PETSC ERROR: -gamg_est_ksp_type cg
[0]PETSC ERROR: -ksp_converged_reason
[0]PETSC ERROR: -ksp_monitor
[0]PETSC ERROR: -ksp_type cg
[0]PETSC ERROR: -malloc_test
[0]PETSC ERROR: -mat_block_size 3
[0]PETSC ERROR: -mg_levels_esteig_ksp_type cg
[0]PETSC ERROR: -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05
[0]PETSC ERROR: -mg_levels_ksp_type chebyshev
[0]PETSC ERROR: -mg_levels_sub_pc_type lu
[0]PETSC ERROR: -ne 3
[0]PETSC ERROR: -pc_gamg_agg_nsmooths 1
[0]PETSC ERROR: -pc_gamg_asm_use_agg
[0]PETSC ERROR: -pc_gamg_coarse_eq_limit 10
[0]PETSC ERROR: -pc_gamg_reuse_interpolation true
[0]PETSC ERROR: -pc_gamg_square_graph 1
[0]PETSC ERROR: -pc_gamg_type agg
[0]PETSC ERROR: -pc_type gamg
[0]PETSC ERROR: -two_solves true
[0]PETSC ERROR: -use_mat_nearnullspace
[0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 77) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=77
system msg for write_line failure : Bad file descriptor
> On Jul 3, 2016, at 9:04 AM, Mark Adams <mfadams at lbl.gov> wrote:
> Barry, I have never seen an empty matrix for this problem. I am in my branch (mark/fix-gamg-asm-aggs), which basically just has the fix to add a dummy block for BCs to make ASM work properly, added to your branch.
> This (appended) is what I get with 1 proc (it is fine, it is solving) . With 8 procs I get this stack trace. I will keep digging.
> #8 main (argc=36, args=0x7fffffff4628) at /global/homes/m/madams/petsc/src/ksp/ksp/examples/tutorials/ex56.c:280 (at 0x0000000000409f2e)
> #7 KSPSetUp (ksp=0x46e2f20) at /global/u2/m/madams/petsc/src/ksp/ksp/interface/itfunc.c:393 (at 0x000000000075d99f)
> #6 PCSetUp (pc=0x46e2f20) at /global/u2/m/madams/petsc/src/ksp/pc/interface/precon.c:968 (at 0x00000000007531da)
> #5 PCSetUp_GAMG (pc=0x46e2f20) at /global/u2/m/madams/petsc/src/ksp/pc/impls/gamg/gamg.c:672 (at 0x0000000000c28a81)
> #4 PCSetUp_MG (pc=0x4760330) at /global/u2/m/madams/petsc/src/ksp/pc/impls/mg/mg.c:781 (at 0x0000000000c87f7e)
> #3 KSPSetUp (ksp=0x46e2f20) at /global/u2/m/madams/petsc/src/ksp/ksp/interface/itfunc.c:393 (at 0x000000000075d99f)
> #2 PCSetUp (pc=0x46e2f20) at /global/u2/m/madams/petsc/src/ksp/pc/interface/precon.c:968 (at 0x00000000007531da)
> #1 PCSetUp_ASM (pc=0x46e2f20) at /global/u2/m/madams/petsc/src/ksp/pc/impls/asm/asm.c:383 (at 0x0000000000c5c499)
> #0 MatGetSubMatrices (mat=0x46e2f20, n=63418000, irow=0x21, icol=0x4a8, scall=MAT_INITIAL_MATRIX, submat=0x2) at /global/u2/m/madams/petsc/src/mat/interface/matrix.c:6780 (at 0x00000000004e8bcd)
> 06:32 134 nid00015 ~/petsc/src/ksp/ksp/examples/tutorials$ srun -n 1 ./ex56 -ne 3 -alpha 1.e-3 -ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 10 -pc_gamg_reuse_interpolation true -two_solves true -ksp_converged_reason -use_mat_nearnullspace -mg_levels_esteig_ksp_type cg -pc_gamg_square_graph 1 -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -gamg_est_ksp_type cg -gamg_est_ksp_max_it 20 -pc_gamg_asm_use_agg -mg_levels_sub_pc_type lu -ksp_monitor
> 0 KSP Residual norm 2.553528059796e+02
> 1 KSP Residual norm 1.285760737388e+01
> 2 KSP Residual norm 5.896306650166e-01
> 3 KSP Residual norm 3.206061310861e-02
> 4 KSP Residual norm 3.287356003543e-03
> 5 KSP Residual norm 1.695272457611e-04
> Linear solve converged due to CONVERGED_RTOL iterations 5
> 0 KSP Residual norm 2.553528059796e-03
> 1 KSP Residual norm 1.285760737388e-04
> 2 KSP Residual norm 5.896306650166e-06
> 3 KSP Residual norm 3.206061310861e-07
> 4 KSP Residual norm 3.287356003543e-08
> 5 KSP Residual norm 1.695272457611e-09
> 0 KSP Residual norm 2.553528059796e-08
> 1 KSP Residual norm 1.285760737388e-09
> 2 KSP Residual norm 5.896306650166e-11
> 3 KSP Residual norm 3.206061310861e-12
> 4 KSP Residual norm 3.287356003543e-13
> 5 KSP Residual norm 1.695272457611e-14
> [0]main |b-Ax|/|b|=9.327411e-06, |b|=7.453560e+00, emax=9.907752e-01
> On Wed, Jun 29, 2016 at 1:05 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Mark
> When I run with exactly the options in this file on either 1 or 8 process and MatView() the matrix you pass to KSP the matrix has ALL zeros. So of course the GAMG solver is not happy. Is the matrix suppose to have all zeros? When I run the command line options in the make file for runex56 the matrix has nonzero values in it and GAMG runs fine.
> Barry
> > On Jun 27, 2016, at 6:56 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > Barry,
> > I am having problems with your branch on ksp/ex56. First I was getting an error with the increase of the overlap that you added (I don't want that to be the default). So I set this back to 0 in gamg.c.
> > Next, I get the same error with the vec out of range because ex56 has BCs in the matrix. I created a branch mark/fix-gamg-asm-aggs from your branch and added the dummy ASM block. But I am getting all kinds of errors. I get errors in get MatSubMatrix and a funny error when it tries to free a prefix string.
> > I've attached the valgrind output of one process, of 8. There is a lot of noise with string operations but it looks like the first non-string thing is in MatGetSubMatrices. ex56 is elasticity. Maybe there is a block size problem?
> > <out_val_1>
