[petsc-dev] MKL issue
Jed Brown
jed at jedbrown.org
Thu Jan 28 23:11:27 CST 2016
Stefano Zampini <stefano.zampini at gmail.com> writes:
> Just for the records:
> I have an installation using the MKL distribution of scalapack but it
> doesn't use IntelMPI
> I've just got a very strange error using MUMPS from PETSc
> Intel MKL FATAL ERROR: Cannot load symbol MKLMPI_Get_wrappers.
> The error goes away with -mat_mumps_icntl_13 1 (which disables ScaLAPACK)
Do you want that to happen automatically? Could we try and catch the
error instead of relying on configure to determine this run-time bug?
> This issue is related with
> https://software.intel.com/en-us/articles/using-intel-mkl-mpi-wrapper-with-the-intel-mkl-cluster-functions
> Is it something we can check for at configure time or we just wait that
> Intel ships MKL with a shared version of libmkl_blacs_(i)lp64?
You can write a test for it or wait. Since the test needs to execute
code, it would need to run as part of conftest on a batch system.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160128/ae0df182/attachment.sig>
