[petsc-dev] Install step broken
Thu Jan 28 09:40:33 CST 2016
On Wed, Jan 27, 2016 at 9:10 AM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
> The 'install' step for master is broken for me since Matt's change ddc4758
> https://bitbucket.org/petsc/petsc/commits/ddc47588dc986180af4263ab160cc4a555099aa9).
> I can  build and install c502958 fine.
This change is only in an error branch, and should only be triggered by an
unsuccessful configure. Can you send configure.log?
     Matt
> Error at 'make install' is:
> No cached configure in RDict at arch-linux2-c-opt/lib/petsc/conf/RDict.db
>                                     Traceback (most recent call last):
>   File "./config/install.py", line 380, in <module>
>     Installer(sys.argv[1:]).run()
>   File "./config/install.py", line 373, in run
>     self.runsetup()
>   File "./config/install.py", line 334, in runsetup
>     self.setup()
>   File "./config/install.py", line 60, in setup
>     self.setupModules()
>   File "./config/install.py", line 51, in setupModules
>     self.setCompilers  = self.framework.require('config.setCompilers',
>     None)
> AttributeError: 'NoneType' object has no attribute 'require'
> makefile:261: recipe for target 'install' failed
> Garth
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160128/6baf3be3/attachment.html>
