[petsc-dev] clash of --download-xxx with something in /usr/include /usr/local/include
Satish Balay
balay at mcs.anl.gov
Wed Jan 27 14:15:09 CST 2016
Its fine to have duplicates in default location.
The issue is with using 'gcc -I/usr/include'
i.e 'gcc -I/my/location' will work - irrespective of any packages
installed in default location But 'gcc -I/usr/include -I/my/location'
will break.
However - if one wants to pick up some packages from /usr/local - but
[or /sw/include] - and not others - i.e locations that are not
compiler defaults - that can cause grief..
Satish
On Wed, 27 Jan 2016, Barry Smith wrote:
> On a different tack, maybe try to find the include file with the default paths BEFORE running the download/install and then stopping and telling the person they are already there in a dangerous place?
> Barry
> > On Jan 27, 2016, at 2:00 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > I guess something like the following might work:
> > For any include file configure checks - it preserves the signature of
> > its location and dependencies [and locadtions]. I think a
> > 'preprocessed file' will have the relavent info/signature.
> > And at the end of configure - these signatures [preprcessed files]
> > have to be regenerated - and compare..
> > Satish
> >> When one runs for example --download-hd5f but there are hdf5 include files in /usr/include or /usr/local/include different compile stages, for example for different external packages, may use the wrong include files leading to very confusing failed builds.
> >> Is there any systematic tests we could add in configure that could detect this type of potential problem and error out or warn?
> >> Thanks
> >> Barry
