[petsc-dev] Install step broken
    Garth N. Wells
    gnw20 at cam.ac.uk
    Wed Jan 27 09:10:41 CST 2016
The 'install' step for master is broken for me since Matt's change ddc4758 (
https://bitbucket.org/petsc/petsc/commits/ddc47588dc986180af4263ab160cc4a555099aa9).
I can  build and install c502958 fine.
Error at 'make install' is:
No cached configure in RDict at arch-linux2-c-opt/lib/petsc/conf/RDict.db
                                  Traceback (most recent call last):
  File "./config/install.py", line 380, in <module>
    Installer(sys.argv[1:]).run()
  File "./config/install.py", line 373, in run
    self.runsetup()
  File "./config/install.py", line 334, in runsetup
    self.setup()
  File "./config/install.py", line 60, in setup
    self.setupModules()
  File "./config/install.py", line 51, in setupModules
    self.setCompilers  = self.framework.require('config.setCompilers',
    None)
AttributeError: 'NoneType' object has no attribute 'require'
makefile:261: recipe for target 'install' failed
Garth
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160127/44d2907d/attachment.html>
