[petsc-dev] valgrind errors in hypre runs
    Barry Smith
    bsmith at mcs.anl.gov
    Sat Jan 16 12:34:37 CST 2016
  Hypre folks,
    When running PETSc examples with hypre we see valgrind warning messages about copying uninitialized data in MPI calls in hype. This is cause by hypre allocating some buffer space, but only putting values in part of the buffer and then sending the entire buffer via MPI to some other process. Technically this is not an "error" if you never access the non initialized data on the receiver process but it makes valgrind unusable for finding TRUE memory issues (since the output is filled with false positives).
   The issue could be fixed by either 1) initializing the complete buffer allocated (for example when it is malloced), then MPI won't see uninitialized data or better IMHO 2) send shorter messages that don't contain this part of the buffer that is never used anyway.
   Thanks
   Barry
> ==17317== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==17317==    at 0xE11ACDB: writev (writev.c:51)
> ==17317==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> ==17317==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> ==17317==    by 0xDA760DD: MPIDI_CH3_iStartMsgv (ch3_istartmsgv.c:110)
> ==17317==    by 0xDA42DF3: MPIDI_CH3_EagerContigSend (ch3u_eager.c:182)
> ==17317==    by 0xDA5FB6A: MPID_Send (mpid_send.c:143)
> ==17317==    by 0xD93C26B: PMPI_Send (send.c:127)
> ==17317==    by 0x695317B: hypre_MPI_Send (mpistubs.c:988)
> ==17317==    by 0x6950F50: hypre_DataExchangeList (exchange_data.c:392)
> ==17317==    by 0x68A49F2: hypre_NewCommPkgCreate_core (new_commpkg.c:267)
> ==17317==    by 0x68A799F: hypre_MatvecCommPkgCreate (par_csr_communication.c:478)
> ==17317==    by 0x6878EB9: hypre_BoomerAMGCreateS (par_strength.c:190)
> ==17317==    by 0x67F90FD: hypre_BoomerAMGSetup (par_amg_setup.c:883)
> ==17317==    by 0x67EDBFD: HYPRE_BoomerAMGSetup (HYPRE_parcsr_amg.c:52)
> ==17317==    by 0x5FAB506: PCSetUp_HYPRE (hypre.c:229)
> ==17317==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> ==17317==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> ==17317==    by 0x405E42: main (ex10.c:316)
> ==17317==  Address 0xf54fe38 is 8 bytes inside a block of size 28 alloc'd
> ==17317==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==17317==    by 0x69518E1: hypre_MAlloc (hypre_memory.c:62)
> ==17317==    by 0x695083F: hypre_DataExchangeList (exchange_data.c:212)
> ==17317==  Uninitialised value was created by a heap allocation
> ==17317==
> ==17318== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==17318==    at 0xE11ACDB: writev (writev.c:51)
> ==17318==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> ==17318==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> ==17318==    by 0xDA760DD: MPIDI_CH3_iStartMsgv (ch3_istartmsgv.c:110)
> ==17318==    by 0xDA42DF3: MPIDI_CH3_EagerContigSend (ch3u_eager.c:182)
> ==17319== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==17318==    by 0xDA5FB6A: MPID_Send (mpid_send.c:143)
> ==17319==    at 0xE11ACDB: writev (writev.c:51)
> ==17319==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> ==17319==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> ==17319==    by 0xDA760DD: MPIDI_CH3_iStartMsgv (ch3_istartmsgv.c:110)
> ==17319==    by 0xDA42DF3: MPIDI_CH3_EagerContigSend (ch3u_eager.c:182)
> ==17319==    by 0xDA5FB6A: MPID_Send (mpid_send.c:143)
> ==17319==    by 0xD93C26B: PMPI_Send (send.c:127)
> ==17319==    by 0x695317B: hypre_MPI_Send (mpistubs.c:988)
> ==17319==    by 0x6950F50: hypre_DataExchangeList (exchange_data.c:392)
> ==17319==    by 0x68A49F2: hypre_NewCommPkgCreate_core (new_commpkg.c:267)
> ==17319==    by 0x68A799F: hypre_MatvecCommPkgCreate (par_csr_communication.c:478)
> ==17319==    by 0x6878EB9: hypre_BoomerAMGCreateS (par_strength.c:190)
> ==17319==    by 0x67F90FD: hypre_BoomerAMGSetup (par_amg_setup.c:883)
> ==17319==    by 0x67EDBFD: HYPRE_BoomerAMGSetup (HYPRE_parcsr_amg.c:52)
> ==17318==    by 0xD93C26B: PMPI_Send (send.c:127)
> ==17318==    by 0x695317B: hypre_MPI_Send (mpistubs.c:988)
> ==17318==    by 0x6950F50: hypre_DataExchangeList (exchange_data.c:392)
> ==17318==    by 0x68A49F2: hypre_NewCommPkgCreate_core (new_commpkg.c:267)
> ==17319==    by 0x5FAB506: PCSetUp_HYPRE (hypre.c:229)
> ==17318==    by 0x68A799F: hypre_MatvecCommPkgCreate (par_csr_communication.c:478)
> ==17318==    by 0x6878EB9: hypre_BoomerAMGCreateS (par_strength.c:190)
> ==17318==    by 0x67F90FD: hypre_BoomerAMGSetup (par_amg_setup.c:883)
> ==17318==    by 0x67EDBFD: HYPRE_BoomerAMGSetup (HYPRE_parcsr_amg.c:52)
> ==17318==    by 0x5FAB506: PCSetUp_HYPRE (hypre.c:229)
> ==17318==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> ==17318==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> ==17318==    by 0x405E42: main (ex10.c:316)
> ==17318==  Address 0xf4dd578 is 8 bytes inside a block of size 28 alloc'd
> ==17318==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==17318==    by 0x69518E1: hypre_MAlloc (hypre_memory.c:62)
> ==17318==    by 0x695083F: hypre_DataExchangeList (exchange_data.c:212)
> ==17318==  Uninitialised value was created by a heap allocation
> ==17318==
> ==17319==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> ==17319==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> ==17319==    by 0x405E42: main (ex10.c:316)
> ==17319==  Address 0xf4dcfb8 is 8 bytes inside a block of size 28 alloc'd
> ==17319==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==17319==    by 0x69518E1: hypre_MAlloc (hypre_memory.c:62)
> ==17319==    by 0x695083F: hypre_DataExchangeList (exchange_data.c:212)
> ==17319==  Uninitialised value was created by a heap allocation
> ==17319==
/sandbox/petsc/petsc.clone/src/ksp/ksp/examples/tutorials
Possible problem with ex10_17, diffs above
0a1,92
> ==17384== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==17384==    at 0xE11ACDB: writev (writev.c:51)
> ==17384==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> ==17384==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> ==17384==    by 0xDA760DD: MPIDI_CH3_iStartMsgv (ch3_istartmsgv.c:110)
> ==17384==    by 0xDA42DF3: MPIDI_CH3_EagerContigSend (ch3u_eager.c:182)
> ==17384==    by 0xDA5FB6A: MPID_Send (mpid_send.c:143)
> ==17384==    by 0xD93C26B: PMPI_Send (send.c:127)
> ==17384==    by 0x695317B: hypre_MPI_Send (mpistubs.c:988)
> ==17384==    by 0x6950F50: hypre_DataExchangeList (exchange_data.c:392)
> ==17384==    by 0x68A49F2: hypre_NewCommPkgCreate_core (new_commpkg.c:267)
> ==17384==    by 0x68A799F: hypre_MatvecCommPkgCreate (par_csr_communication.c:478)
> ==17384==    by 0x6878EB9: hypre_BoomerAMGCreateS (par_strength.c:190)
> ==17384==    by 0x67F90FD: hypre_BoomerAMGSetup (par_amg_setup.c:883)
> ==17384==    by 0x67EDBFD: HYPRE_BoomerAMGSetup (HYPRE_parcsr_amg.c:52)
> ==17384==    by 0x5FAB506: PCSetUp_HYPRE (hypre.c:229)
> ==17384==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> ==17384==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> ==17384==    by 0x405E42: main (ex10.c:316)
> ==17384==  Address 0xf49cf38 is 8 bytes inside a block of size 28 alloc'd
> ==17384==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==17384==    by 0x69518E1: hypre_MAlloc (hypre_memory.c:62)
> ==17384==    by 0x695083F: hypre_DataExchangeList (exchange_data.c:212)
> ==17384==  Uninitialised value was created by a heap allocation
> ==17384==
> ==17383== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==17383==    at 0xE11ACDB: writev (writev.c:51)
> ==17383==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> ==17383==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> ==17383==    by 0xDA760DD: MPIDI_CH3_iStartMsgv (ch3_istartmsgv.c:110)
> ==17383==    by 0xDA42DF3: MPIDI_CH3_EagerContigSend (ch3u_eager.c:182)
> ==17383==    by 0xDA5FB6A: MPID_Send (mpid_send.c:143)
> ==17383==    by 0xD93C26B: PMPI_Send (send.c:127)
> ==17383==    by 0x695317B: hypre_MPI_Send (mpistubs.c:988)
> ==17383==    by 0x6950F50: hypre_DataExchangeList (exchange_data.c:392)
> ==17383==    by 0x68A49F2: hypre_NewCommPkgCreate_core (new_commpkg.c:267)
> ==17383==    by 0x68A799F: hypre_MatvecCommPkgCreate (par_csr_communication.c:478)
> ==17383==    by 0x6878EB9: hypre_BoomerAMGCreateS (par_strength.c:190)
> ==17383==    by 0x67F90FD: hypre_BoomerAMGSetup (par_amg_setup.c:883)
> ==17383==    by 0x67EDBFD: HYPRE_BoomerAMGSetup (HYPRE_parcsr_amg.c:52)
> ==17383==    by 0x5FAB506: PCSetUp_HYPRE (hypre.c:229)
> ==17383==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> ==17383==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> ==17383==    by 0x405E42: main (ex10.c:316)
> ==17383==  Address 0xf5418d8 is 8 bytes inside a block of size 28 alloc'd
> ==17383==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==17383==    by 0x69518E1: hypre_MAlloc (hypre_memory.c:62)
> ==17383==    by 0x695083F: hypre_DataExchangeList (exchange_data.c:212)
> ==17383==  Uninitialised value was created by a heap allocation
> ==17383==
Possible problem with ex10_boomeramg_schwarz, diffs above
0a1,92
> ==17445== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==17445==    at 0xE11ACDB: writev (writev.c:51)
> ==17445==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> ==17445==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> ==17445==    by 0xDA760DD: MPIDI_CH3_iStartMsgv (ch3_istartmsgv.c:110)
> ==17445==    by 0xDA42DF3: MPIDI_CH3_EagerContigSend (ch3u_eager.c:182)
> ==17445==    by 0xDA5FB6A: MPID_Send (mpid_send.c:143)
> ==17445==    by 0xD93C26B: PMPI_Send (send.c:127)
> ==17445==    by 0x695317B: hypre_MPI_Send (mpistubs.c:988)
> ==17445==    by 0x6950F50: hypre_DataExchangeList (exchange_data.c:392)
> ==17445==    by 0x68A49F2: hypre_NewCommPkgCreate_core (new_commpkg.c:267)
> ==17445==    by 0x68A799F: hypre_MatvecCommPkgCreate (par_csr_communication.c:478)
> ==17445==    by 0x6878EB9: hypre_BoomerAMGCreateS (par_strength.c:190)
> ==17445==    by 0x67F90FD: hypre_BoomerAMGSetup (par_amg_setup.c:883)
> ==17445==    by 0x67EDBFD: HYPRE_BoomerAMGSetup (HYPRE_parcsr_amg.c:52)
> ==17445==    by 0x5FAB506: PCSetUp_HYPRE (hypre.c:229)
> ==17445==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> ==17445==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> ==17445==    by 0x405E42: main (ex10.c:316)
> ==17445==  Address 0xf49df88 is 8 bytes inside a block of size 28 alloc'd
> ==17445==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==17445==    by 0x69518E1: hypre_MAlloc (hypre_memory.c:62)
> ==17445==    by 0x695083F: hypre_DataExchangeList (exchange_data.c:212)
> ==17445==  Uninitialised value was created by a heap allocation
> ==17445==
> ==17444== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==17444==    at 0xE11ACDB: writev (writev.c:51)
> ==17444==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> ==17444==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> ==17444==    by 0xDA760DD: MPIDI_CH3_iStartMsgv (ch3_istartmsgv.c:110)
> ==17444==    by 0xDA42DF3: MPIDI_CH3_EagerContigSend (ch3u_eager.c:182)
> ==17444==    by 0xDA5FB6A: MPID_Send (mpid_send.c:143)
> ==17444==    by 0xD93C26B: PMPI_Send (send.c:127)
> ==17444==    by 0x695317B: hypre_MPI_Send (mpistubs.c:988)
> ==17444==    by 0x6950F50: hypre_DataExchangeList (exchange_data.c:392)
> ==17444==    by 0x68A49F2: hypre_NewCommPkgCreate_core (new_commpkg.c:267)
> ==17444==    by 0x68A799F: hypre_MatvecCommPkgCreate (par_csr_communication.c:478)
> ==17444==    by 0x6878EB9: hypre_BoomerAMGCreateS (par_strength.c:190)
> ==17444==    by 0x67F90FD: hypre_BoomerAMGSetup (par_amg_setup.c:883)
> ==17444==    by 0x67EDBFD: HYPRE_BoomerAMGSetup (HYPRE_parcsr_amg.c:52)
> ==17444==    by 0x5FAB506: PCSetUp_HYPRE (hypre.c:229)
> ==17444==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> ==17444==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> ==17444==    by 0x405E42: main (ex10.c:316)
> ==17444==  Address 0xf542928 is 8 bytes inside a block of size 28 alloc'd
> ==17444==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==17444==    by 0x69518E1: hypre_MAlloc (hypre_memory.c:62)
> ==17444==    by 0x695083F: hypre_DataExchangeList (exchange_data.c:212)
> ==17444==  Uninitialised value was created by a heap allocation
> ==17444==
Possible problem with ex10_boomeramg_parasails, diffs above
0a1,92
> ==17505== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==17505==    at 0xE11ACDB: writev (writev.c:51)
> ==17505==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> ==17505==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> ==17505==    by 0xDA760DD: MPIDI_CH3_iStartMsgv (ch3_istartmsgv.c:110)
> ==17505==    by 0xDA42DF3: MPIDI_CH3_EagerContigSend (ch3u_eager.c:182)
> ==17505==    by 0xDA5FB6A: MPID_Send (mpid_send.c:143)
> ==17505==    by 0xD93C26B: PMPI_Send (send.c:127)
> ==17505==    by 0x695317B: hypre_MPI_Send (mpistubs.c:988)
> ==17505==    by 0x6950F50: hypre_DataExchangeList (exchange_data.c:392)
> ==17505==    by 0x68A49F2: hypre_NewCommPkgCreate_core (new_commpkg.c:267)
> ==17505==    by 0x68A799F: hypre_MatvecCommPkgCreate (par_csr_communication.c:478)
> ==17505==    by 0x6878EB9: hypre_BoomerAMGCreateS (par_strength.c:190)
> ==17505==    by 0x67F90FD: hypre_BoomerAMGSetup (par_amg_setup.c:883)
> ==17505==    by 0x67EDBFD: HYPRE_BoomerAMGSetup (HYPRE_parcsr_amg.c:52)
> ==17505==    by 0x5FAB506: PCSetUp_HYPRE (hypre.c:229)
> ==17505==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> ==17505==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> ==17505==    by 0x405E42: main (ex10.c:316)
> ==17505==  Address 0xf49df88 is 8 bytes inside a block of size 28 alloc'd
> ==17505==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==17505==    by 0x69518E1: hypre_MAlloc (hypre_memory.c:62)
> ==17505==    by 0x695083F: hypre_DataExchangeList (exchange_data.c:212)
> ==17505==  Uninitialised value was created by a heap allocation
> ==17505==
> ==17504== Syscall param writev(vector[...]) points to uninitialised byte(s)
> ==17504==    at 0xE11ACDB: writev (writev.c:51)
> ==17504==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> ==17504==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> ==17504==    by 0xDA760DD: MPIDI_CH3_iStartMsgv (ch3_istartmsgv.c:110)
> ==17504==    by 0xDA42DF3: MPIDI_CH3_EagerContigSend (ch3u_eager.c:182)
> ==17504==    by 0xDA5FB6A: MPID_Send (mpid_send.c:143)
> ==17504==    by 0xD93C26B: PMPI_Send (send.c:127)
> ==17504==    by 0x695317B: hypre_MPI_Send (mpistubs.c:988)
> ==17504==    by 0x6950F50: hypre_DataExchangeList (exchange_data.c:392)
> ==17504==    by 0x68A49F2: hypre_NewCommPkgCreate_core (new_commpkg.c:267)
> ==17504==    by 0x68A799F: hypre_MatvecCommPkgCreate (par_csr_communication.c:478)
> ==17504==    by 0x6878EB9: hypre_BoomerAMGCreateS (par_strength.c:190)
> ==17504==    by 0x67F90FD: hypre_BoomerAMGSetup (par_amg_setup.c:883)
> ==17504==    by 0x67EDBFD: HYPRE_BoomerAMGSetup (HYPRE_parcsr_amg.c:52)
> ==17504==    by 0x5FAB506: PCSetUp_HYPRE (hypre.c:229)
> ==17504==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> ==17504==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> ==17504==    by 0x405E42: main (ex10.c:316)
> ==17504==  Address 0xf542928 is 8 bytes inside a block of size 28 alloc'd
> ==17504==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==17504==    by 0x69518E1: hypre_MAlloc (hypre_memory.c:62)
> ==17504==    by 0x695083F: hypre_DataExchangeList (exchange_data.c:212)
> ==17504==  Uninitialised value was created by a heap allocation
> ==17504==
7c99
< Residual norm 8.60096e-11
