[petsc-dev] Contribution proposal about the application of PCShell as left and right preconditioner
Sylvain Mercier
sylvainmercier85 at gmail.com
Sat Jan 9 15:06:39 CST 2016
Dear PETSc team,
During my phd thesis, I have worked on solving sequences of linear
systems with slowly varying matrices using GMRES(restart). In
particular, I have developed a preconditioning technique to improve
the action of an existing "first-level preconditioner". This new
method is usually applied as right preconditioner with a PCShell, although
the first preconditioner is applied on the left.
That is why I have developed routines in PETSc to be able to apply
simultaneously a left and a right PCShells when we use a PC_SYMMETRIC
PCSIDE. In fact, I have add two routines: PCShellSetApplySymmetricLeft and
PCShellSetApplySymmetricRight (similarly to the routine PCShellSetApply).
Moreover, I have added the possibility to use a PC_SYMMETRIC preconditioner
within GMRES.
I gently request your position on the integration of these developments in
PETSc. I have some problems to provide a pull-request via a fork so I
propose a patch. Let me know if you want extra integration work.
Best regards,
Sylvain.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160109/ef2b684f/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160109/ef2b684f/attachment.bin>
