[petsc-dev] Not possible to do a VecPlaceArray for veccusp
    Jeff Hammond
    jeff.science at gmail.com
    Sun Feb 28 12:51:59 CST 2016
On Sunday, February 28, 2016, Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
> Hi,
> I like the idea of having separate VECCUDA and VECVIENNACL, because it is
>> possible to implement VECCUDA without dependence on a C++ compiler (only
>> the CUDA compiler).
> I don't understand this part. NVCC also requires a C++ host compiler and
> is fairly picky about the supported compilers.
> If you want, we can prepare a rough initial implementation of VECCUDA in
>> the next days, and we can later discuss what to keep/discard.
> Any contributions are welcome :-)
> Karl: regarding the time constraints, our idea is to present something at
>> a conference this summer, and deadlines are approaching.
> Ok, this is on fairly short notice considering the changes required. I
> recommend to start with copying the CUSP sources and migrate it over to
> VECCUDA by replacing any use of cusp::array1d to a raw CUDA handle.
> Operations from CUSP should be replaced by CUBLAS calls.
It's hard to imagine any performance benefit from this unless CUSP sucks.
What am I missing?
Jeff
> Best regards,
> Karli
>>>>> If there is interest we can help in adding this stuff.
>>>> What are your time constraints?
>>>> Best regards,
>>>> Karli
>>> Dominic Meiser
>>> Tech-X Corporation - 5621 Arapahoe Avenue - Boulder, CO 80303
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160228/e4bc996a/attachment.html>
