[petsc-dev] snes_monitor_residual
Mark Adams
mfadams at lbl.gov
Thu Dec 22 07:30:44 CST 2016
> That will stash vectors in the HDF5 file, but you still need to put in the
> DM as well
> -dm_view hdf5:ex1.h5
> -snes_monitor_residual hdf5:ex1.h5::append
> -snes_monitor_solution hdf5:ex1.h5::append
I tried:
#PETSc Option Table entries:
-dm_view hdf5:res.h5
-snes_monitor_residual hdf5:res.h5::append
And see this:
#End of PETSc Option Table entries
There is one unused database option. It is:
Option left: name:-dm_view value: hdf5:res.h5
And, of course, I get the same bad h5 file as before. In other codes I have
had to add code. I tried simply adding
ierr = DMViewFromOptions(ctx->dm,NULL,"-dm_view");CHKERRQ(ierr);
before the solve, but that did not change anything (same bad h5 file) other
than remove the 'options left' warning.
I tried to clone the code that I use for printing vectors manually by
adding this before the solve:
ierr =
PetscOptionsGetViewer(PETSC_COMM_SELF,NULL,"-snes_monitor_residual",&viewer,&fmt,&flg);CHKERRQ(ierr);
if (flg) {
ierr = PetscViewerPushFormat(viewer,fmt);CHKERRQ(ierr);
But got this error in the solve:
0 SNES Function norm 4.438513482798e+01
HDF5-DIAG: Error detected in HDF5 (1.8.12) MPI-process 0:
#000: H5L.c line 824 in H5Lexists(): unable to get link info
major: Symbol table
minor: Object not found
#001: H5L.c line 2765 in H5L_exists(): path doesn't exist
major: Symbol table
minor: Object already exists
#002: H5Gtraverse.c line 861 in H5G_traverse(): internal path traversal
failed
major: Symbol table
#003: H5Gtraverse.c line 596 in H5G_traverse_real(): can't look up
component
major: Symbol table
#004: H5Gobj.c line 1156 in H5G__obj_lookup(): can't locate object
major: Symbol table
#005: H5Gstab.c line 907 in H5G__stab_lookup(): not found
major: Symbol table
#006: H5B.c line 366 in H5B_find(): can't lookup key in leaf node
major: B-Tree node
#007: H5Gnode.c line 545 in H5G_node_found(): unable to protect symbol
table node
major: Symbol table
minor: Unable to load metadata into cache
#008: H5AC.c line 1329 in H5AC_protect(): H5C_protect() failed.
major: Object cache
minor: Unable to protect metadata
#009: H5C.c line 3574 in H5C_protect(): can't load entry
major: Object cache
#010: H5C.c line 7954 in H5C_load_entry(): unable to load entry
major: Object cache
#011: H5Gcache.c line 169 in H5G_node_load(): bad symbol table node
signature
major: Symbol table
#000: H5D.c line 334 in H5Dopen2(): not found
major: Dataset
#001: H5Gloc.c line 430 in H5G_loc_find(): can't find object
major: Symbol table
failed
major: Symbol table
component
major: Symbol table
major: Symbol table
major: Symbol table
major: B-Tree node
table node
major: Symbol table
major: Object cache
major: Object cache
major: Object cache
signature
major: Symbol table
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161222/dc578459/attachment.html>
