[petsc-dev] Cannot reuse matrix of type (null)
Stefano Zampini stefano.zampini at gmail.com
Fri Dec 16 12:06:15 CST 2016
What about raising an error from the interface if mat_reuse_matrix is
requested with the same input and output matrix?
Il 16 dic 2016 8:37 PM, "Barry Smith" <bsmith at mcs.anl.gov> ha scritto:
>   I have added more words to the manual page for MatConvert() to make the
> MatReuse easier to understand.
> > On Dec 16, 2016, at 7:50 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >  Eric,
> >    Perhaps you should be using MAT_INPLACE_MATRIX?
> >    The documentation is not as clear as it should be on
> MAT_INPLACE_MATRIX vs MAT_REUSE_MATRIX and it is possible that some
> implementations of MatConvert_xxx() are broken and do not use this flag
> properly.
> > MAT_INPLACE_MATRIX  means replace the input matrix with the matrix of
> the new type
> > MAT_REUSE_MATRIX means reuse the matrix that has been passed in as the
> final value (that matrix must have come from a previous call to
> MatConvert() with the flag MAT_INITIAL_MATRIX)
> >  Barry
> >> On Dec 16, 2016, at 7:43 AM, Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
> >> Actually, the matrix type has not yet been set (since you have "null"
> in your output)
> >> 2016-12-16 16:43 GMT+03:00 Stefano Zampini <stefano.zampini at gmail.com>:
> >> Looking at lines 113-115 of master
> >> if (reuse == MAT_REUSE_MATRIX) {
> >>    ierr = PetscObjectTypeCompare((PetscObject)*newmat,
> MATSEQDENSE,&isseqdense);CHKERRQ(ierr);
> >>    if (!isseqdense) SETERRQ1(PetscObjectComm((
> PetscObject)*newmat),PETSC_ERR_USER,"Cannot reuse matrix of type
> %s",((PetscObject)(*newmat))->type);
> >> you are trying to call MatConvert with the reuse flag on a matrix which
> is not of type SeqDense. Can you provide a MWE to reproduce the problem?
> >> Thanks,
> >> Stefano
> >> 2016-12-16 16:39 GMT+03:00 Eric Chamberland <Eric.Chamberland at giref.
> ulaval.ca>:
> >> Another precision: the problem may still be there since dec 15, not
> tonight...
> >> Eric
> >> On 16/12/16 08:30 AM, Eric Chamberland wrote:
> >> Hi,
> >> something seems broken with master branch since last night.
> >> With our nighlty tests, we now have many times this PETSC ERROR:
> >> [0]PETSC ERROR: Cannot reuse matrix of type (null)
> >> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> >> for trouble shooting.
> >> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.4-2508-ga46e98f GIT
> >> Date: 2016-12-14 17:44:47 -0600
> >> [0]PETSC ERROR:
> >> /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/
> COMPILE_AUTO/BIB/bin/Test.BIBProblemeGD.dev
> >> on a arch-linux2-c-debug named compile by Unknown Fri Dec 16 03:06:00
> 2016
> >> [0]PETSC ERROR: Configure options --prefix=/opt/petsc-master_debug
> >> --with-mpi-compilers=1 --with-make-np=12 --with-shared-libraries=1
> >> --with-mpi-dir=/opt/openmpi-1.10.2 --with-debugging=yes
> >> --with-mkl_pardiso=1 --with-mkl_pardiso-dir=/opt/intel/composerxe/mkl
> >> --download-ml=yes --download-mumps=yes --download-superlu=yes
> >> --download-superlu_dist=yes --download-parmetis=yes
> >> --download-ptscotch=yes --download-metis=yes --download-suitesparse=yes
> >> --download-hypre=yes --with-scalapack=1
> >> --with-scalapack-include=/opt/intel/composerxe/mkl/include
> >> --with-scalapack-lib="-L/opt/intel/composerxe/mkl/lib/intel64
> >> -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
> >> --with-blas-lapack-dir=/opt/intel/composerxe/mkl/lib/intel64
> >> [0]PETSC ERROR: #1 MatConvert_SeqAIJ_SeqDense() line 115 in
> COMPILE_AUTO/petsc-master-debug/src/mat/impls/dense/seq/dense.c
> >> [0]PETSC ERROR: #2 MatConvert() line 4136 in
> COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
> >> With all other PETSc versions we use, with the same tests, we do not
> >> have this problem.
> >> Here are the configure/build logs:
> >> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/
> 2016.12.16.02h00m01s_configure.log
> 2016.12.16.02h00m01s_make.log
> 2016.12.16.02h00m01s_RDict.log
> 2016.12.16.02h00m01s_CMakeLists.txt
> >> Is it a normal change or is it a bug?
> >> I can provide more context to help dig into this.
> >> Thanks,
> >> Eric
> >> Stefano
> >> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161216/437dd13c/attachment.html>
