[petsc-dev] Cannot reuse matrix of type (null)
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Fri Dec 16 07:39:37 CST 2016
Another precision: the problem may still be there since dec 15, not
tonight...
Eric
On 16/12/16 08:30 AM, Eric Chamberland wrote:
> Hi,
> something seems broken with master branch since last night.
> With our nighlty tests, we now have many times this PETSC ERROR:
> [0]PETSC ERROR: Cannot reuse matrix of type (null)
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.4-2508-ga46e98f GIT
> Date: 2016-12-14 17:44:47 -0600
> [0]PETSC ERROR:
> /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/BIB/bin/Test.BIBProblemeGD.dev
> on a arch-linux2-c-debug named compile by Unknown Fri Dec 16 03:06:00 2016
> [0]PETSC ERROR: Configure options --prefix=/opt/petsc-master_debug
> --with-mpi-compilers=1 --with-make-np=12 --with-shared-libraries=1
> --with-mpi-dir=/opt/openmpi-1.10.2 --with-debugging=yes
> --with-mkl_pardiso=1 --with-mkl_pardiso-dir=/opt/intel/composerxe/mkl
> --download-ml=yes --download-mumps=yes --download-superlu=yes
> --download-superlu_dist=yes --download-parmetis=yes
> --download-ptscotch=yes --download-metis=yes --download-suitesparse=yes
> --download-hypre=yes --with-scalapack=1
> --with-scalapack-include=/opt/intel/composerxe/mkl/include
> --with-scalapack-lib="-L/opt/intel/composerxe/mkl/lib/intel64
> -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
> --with-blas-lapack-dir=/opt/intel/composerxe/mkl/lib/intel64
> [0]PETSC ERROR: #1 MatConvert_SeqAIJ_SeqDense() line 115 in
> /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/dense/seq/dense.c
> [0]PETSC ERROR: #2 MatConvert() line 4136 in
> /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
> With all other PETSc versions we use, with the same tests, we do not
> have this problem.
> Here are the configure/build logs:
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.12.16.02h00m01s_configure.log
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.12.16.02h00m01s_make.log
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.12.16.02h00m01s_RDict.log
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.12.16.02h00m01s_CMakeLists.txt
> Is it a normal change or is it a bug?
> I can provide more context to help dig into this.
> Thanks,
> Eric
