[petsc-dev] PETSc BILU in parallel
    Jed Brown
    jed at jedbrown.org
    Fri Dec  9 11:09:39 CST 2016
Paolo Orsini <paolo.orsini at gmail.com> writes:
> Thanks for this Jed,
> Any other alternatives you are aware of, for a parallel BILU(0) pre in
> PETSc?
Not that I'm aware of, but there is no magic in blocks (it's purely
implementation efficiency; if those entries are allocated in the matrix
then scalar ILU is equivalent) so long as there aren't zero pivots.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161209/456efda2/attachment.sig>
