[petsc-dev] [petsc-users] SAMG support
Lisandro Dalcin dalcinl at gmail.com
Wed Apr 27 05:51:58 CDT 2016
On 27 April 2016 at 11:53, Patrick Sanan <patrick.sanan at gmail.com> wrote:
> includes), and have them add a single registration line after
> PetscInitialize which makes the new solver usable just as the built-in
> ones are (via the options database and command line arguments).
Actually, if you build your plugin as a shared library, then you can just
-dll_append pcsupercool.so
and get it registered, no need to modify code.
> I don't know of any packages that actually do this - are there some?
Don't know. But I would argue that many packages currently in PETSc
could be reworked as plugins very easily.
Oh! Hold on. We have some support for writing "plugins" in Python, and
we dynamically load the Python shared library to bootstrap the Python
runtime and then petsc4py. And IMHO, this is quite a bit more
complicated that plain C plugins.
> Is this a hassle for reasons I haven't thought through fully yet?
The only hassle would be to updating it after new PETSc releases. And
BTW, you could keep your code compatible with older PETSc releases
with proper processor guards.
A minor issue with dynamically loadable plugins is that using the
command line is the only way to configure the package is through the
command line. But that's a fair price to pay for not having to ever
modify (nor recompile) your code.
> The specific interest I have in this is that a student of Olaf's has
> been working with an interface to (non-MKL) PARDISO which I think
> could be useful, and I'm also interested in there being an interface
> to ILUPack.
Go for it. I can help with comments and review.
PS: I'm not 100% sure about the status of dynamic lib loading in
PETSc, but I can help with any required refactoring of that machinery
to better support plugins.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 0109
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
