[petsc-dev] PETSc release is imminent so please check your loose ends
Fri Apr 22 14:03:05 CDT 2016
   A PETSc release is imminent so please check your loose ends in master. Be very careful about moving any code into master unless you are positive it is not broken and should be in the release. I'd like all the tests to be clean in the release version.
   Thanks
     Barry
Of course we will be releasing patches so if something buggy gets in we can fix it.
