[petsc-dev] Make PetscHash publicly accessible
Fri Apr 22 09:10:27 CDT 2016
On Fri, Apr 22, 2016 at 9:04 AM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Fri, Apr 22, 2016 at 4:32 AM, Lawrence Mitchell <
> > lawrence.mitchell at imperial.ac.uk> wrote:
> >> Hi all,
> >> I would like to use the PetscHash functionality in my code.  At the
> moment
> >> this is not possible, since the header file hash.h is not public (it's
> in
> >> src/sys/utils/hash.h).  Would there be any objections to moving it to
> (say)
> >> include/petschash.h so that PETSc applications can use it as well as
> PETSc
> >> itself.
> > No, go ahead and do it.
> If you do, then you need to namespace everything so it doesn't conflict
> with khash.h from:
>   https://github.com/attractivechaos/klib
>   (or https://github.com/clibs/hash)
> Now personally, if I was writing code that was not intended for eventual
> inclusion in PETSc, I would just use upstream khash.h directly.  (PETSc
> should probably upgrade to the latest upstream khash.h.)
> The PetscHash* wrappers don't add value in my opinion, just consistency
> with PETSc style via lots of lines of code that add PetscErrorCode
> returns that cannot be anything but 0 because the underlying operations
> cannot fail.
Sweeping generalization not actually true. The wrappers do setup the
particular
keys we want inside PETSc, and do bundle some multiple operation calls.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160422/a6dafdec/attachment.html>
