[petsc-dev] --known-mpi-shared-library and --with-batch annoyance
Jed Brown
jed at jedbrown.org
Thu Apr 21 14:09:12 CDT 2016
Barry Smith <bsmith at mcs.anl.gov> writes:
> We generate (or should if we don't) our shared PETSc libraries by
> sharedlink petscsys.so -lmpi
> sharedlink petscvec.so -lpetscsys
If your shared libraries are set up correctly and there is a strict
policy about transitive linking (the correct thing), then this is not
okay because petscvec.so has direct calls to MPI. If libmpi.a (built
with -fPIC) was inlined into petscsys.so, then it would "work" (but be
disgusting).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160421/100d8b41/attachment.sig>
