[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2016-04-08
Satish Balay
balay at mcs.anl.gov
Wed Apr 13 17:29:11 CDT 2016
I pushed the following to get suppress this warning to tisaac/dmp4est-feature-injection [and merged to next]
https://bitbucket.org/petsc/petsc/commits/403a37bcd7a8acbd8d9c14f7e483574a3c3be850
[preferable to the alternative of trying to filter out the warning during post-processing]
Satish
On Wed, 13 Apr 2016, Satish Balay wrote:
> ok - I mixed up DMPlexReferenceTreeRestoreChildrenMatrices_Injection and DMPlexReferenceTreeGetChildrenMatrices_Injection
> Satish
> On Tue, 12 Apr 2016, Tobin Isaac wrote:
> > On Tue, Apr 12, 2016 at 10:42:26PM -0500, Satish Balay wrote:
> > > Ok - I see the bug in this code.
> > > static PetscErrorCode DMPlexReferenceTreeRestoreChildrenMatrices_Injection(DM refTree, Mat inj, PetscScalar ****childrenMats)
> > > Since this funciton is defined as 'static' the compiler is doing
> > > 'inter procedure analysis' across the calling function with -O [this
> > > warning comes up only with -O build]
> > > 1. plextree.c:3506 has the following variable declared [uninitialized]
> > > PetscScalar ***childrenMats;
> > > 2. the next usage of this variable is: plextree.c:3846
> > > ierr = DMPlexReferenceTreeGetChildrenMatrices_Injection(refTree,injRef,&childrenMats);CHKERRQ(ierr);
> > > 3. Within this function - the first usage of this variable is plextree.c:L3453
> > > refPointFieldMats = *childrenMats;
> > > i.e access/use of uninitialized variable.
> > > The following supresses the warning - but there is clearly some lurking bug..
> > A bug in the code, or the analyzer? Like I said, there is a
> > conditional-free path that leads to plextree.c:L3436 (was 3437)---
> > *childrenMats = refPointFieldMats;
> > ---in the Get function before the line in the Restore function that's
> > triggering the warning. Maybe the (shorter) Restore function is being
> > inlined while the Get function isn't, I don't know, but I'm fairly
> > confident this is a false positive.
> > Furthermore, this code is covered by tests in next, but looking at the
> > dashboard I don't see any warnings from the valgrind build.
> > > diff --git a/src/dm/impls/plex/plextree.c b/src/dm/impls/plex/plextree.c
> > > index 2ee02d0..e51f704 100644
> > > --- a/src/dm/impls/plex/plextree.c
> > > +++ b/src/dm/impls/plex/plextree.c
> > > @@ -3503,7 +3503,7 @@ PetscErrorCode DMPlexComputeInjectorTree(DM coarse, DM fine, PetscSF coarseToFin
> > > PetscLayout rowMap, colMap;
> > > PetscInt rowStart, rowEnd, colStart, colEnd, *nnzD, *nnzO;
> > > PetscObject injRefObj;
> > > - PetscScalar ***childrenMats;
> > > + PetscScalar ***childrenMats=0;
> > > PetscErrorCode ierr;
> > > PetscFunctionBegin;
> > > And this was introduced by http://bitbucket.org/petsc/petsc/commits/f30e825d
> > > Satish
> > > On Fri, 8 Apr 2016, Barry Smith wrote:
> > > > Toby,
> > > > We'll be filtering out these false positives. It is just taking us a couple of days to determine that needs to be filtered.
> > > > Barry
> > > > > On Apr 8, 2016, at 2:36 PM, Tobin Isaac <tisaac at uchicago.edu> wrote:
> > > > > I spent a couple minutes verifying that there is no code path where
> > > > > that variable is not initialized on line 3437.
> > > > > -Wmaybe-uninitialized seems to generate a lot of false positives.
> > > > > Coupled with the blame digest's poor ability to assign blame, this
> > > > > proactive approach seems to waste more time than a reactive
> > > > > SEGV->valgrind->fix approach.
> > > > > Cheers,
> > > > > Toby
> > > > > On Fri, Apr 08, 2016 at 02:12:22PM -0500, Satish Balay wrote:
> > > > >> This should have been sent to Toby.
> > > > >> I don't really understand the issue here. Its triggered by --with-debugging=0. I'm
> > > > >> not sure why these compilers are pointing to petscsys.h. I get slightly different message
> > > > >> on my laptop.
> > > > >> mpicc -c -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g -O -I/home/balay/petsc/include -I/home/balay/petsc/arch-linux2-c-opt/include -I/home/balay/soft/mpich-3.1.4/include -MMD -MP /home/balay/petsc/src/dm/impls/plex/plextree.c -o arch-linux2-c-opt/obj/src/dm/impls/plex/plextree.o
> > > > >> /home/balay/petsc/src/dm/impls/plex/plextree.c: In function ‘DMPlexComputeInjectorTree’:
> > > > >> /home/balay/petsc/src/dm/impls/plex/plextree.c:3484:11: warning: ‘childrenMats’ may be used uninitialized in this function [-Wmaybe-uninitialized]
> > > > >> ierr = PetscFree(refPointFieldMats);CHKERRQ(ierr);
> > > > >> /home/balay/petsc/src/dm/impls/plex/plextree.c:3507:18: note: ‘childrenMats’ was declared here
> > > > >> Satish
> > > > >> On Fri, 8 Apr 2016, PETSc checkBuilds wrote:
> > > > >>> Dear PETSc developer,
> > > > >>> This email contains listings of contributions attributed to you by
> > > > >>> `git blame` that caused compiler errors or warnings in PETSc automated
> > > > >>> testing. Follow the links to see the full log files. Please attempt to fix
> > > > >>> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> > > > >>> to resolve the issues.
> > > > >>> Thanks,
> > > > >>> The PETSc development team
> > > > >>> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/49d7da5
> > > > >>> PetscMalloc: allow ptr=malloc(0) and free(ptr)
> > > > >>> include/petscsys.h:1157
> > > > >>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-freebsd-cxx-pkgs-opt_wii.log]
> > > > >>> /usr/home/balay/petsc.clone-2/include/petscsys.h:1157:88: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
> > > > >>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-linux-opt-cxx-quad_grind.log]
> > > > >>> /sandbox/petsc/petsc.clone-3/include/petscsys.h:1157:88: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
> > > > >>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-freebsd-pkgs-opt_wii.log]
> > > > >>> /usr/home/balay/petsc.clone/include/petscsys.h:1157:39: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
> > > > >>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-linux-pkgs-latest_cg.log]
> > > > >>> /sandbox/petsc/petsc.clone-4/include/petscsys.h:1157:25: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
> > > > >>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-linux-pkgs-opt_crank.log]
> > > > >>> /sandbox/petsc/petsc.clone/include/petscsys.h:1157:25: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
> > > > >>> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
