[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2016-04-08
Barry Smith
bsmith at mcs.anl.gov
Fri Apr 8 15:07:18 CDT 2016
Toby,
We'll be filtering out these false positives. It is just taking us a couple of days to determine that needs to be filtered.
Barry
> On Apr 8, 2016, at 2:36 PM, Tobin Isaac <tisaac at uchicago.edu> wrote:
> I spent a couple minutes verifying that there is no code path where
> that variable is not initialized on line 3437.
> -Wmaybe-uninitialized seems to generate a lot of false positives.
> Coupled with the blame digest's poor ability to assign blame, this
> proactive approach seems to waste more time than a reactive
> SEGV->valgrind->fix approach.
> Cheers,
> Toby
> On Fri, Apr 08, 2016 at 02:12:22PM -0500, Satish Balay wrote:
>> This should have been sent to Toby.
>> I don't really understand the issue here. Its triggered by --with-debugging=0. I'm
>> not sure why these compilers are pointing to petscsys.h. I get slightly different message
>> on my laptop.
>> mpicc -c -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g -O -I/home/balay/petsc/include -I/home/balay/petsc/arch-linux2-c-opt/include -I/home/balay/soft/mpich-3.1.4/include -MMD -MP /home/balay/petsc/src/dm/impls/plex/plextree.c -o arch-linux2-c-opt/obj/src/dm/impls/plex/plextree.o
>> /home/balay/petsc/src/dm/impls/plex/plextree.c: In function ‘DMPlexComputeInjectorTree’:
>> /home/balay/petsc/src/dm/impls/plex/plextree.c:3484:11: warning: ‘childrenMats’ may be used uninitialized in this function [-Wmaybe-uninitialized]
>> ierr = PetscFree(refPointFieldMats);CHKERRQ(ierr);
>> /home/balay/petsc/src/dm/impls/plex/plextree.c:3507:18: note: ‘childrenMats’ was declared here
>> PetscScalar ***childrenMats;
>> Satish
>> On Fri, 8 Apr 2016, PETSc checkBuilds wrote:
>>> Dear PETSc developer,
>>> This email contains listings of contributions attributed to you by
>>> `git blame` that caused compiler errors or warnings in PETSc automated
>>> testing. Follow the links to see the full log files. Please attempt to fix
>>> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
>>> to resolve the issues.
>>> Thanks,
>>> The PETSc development team
>>> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/49d7da5
>>> PetscMalloc: allow ptr=malloc(0) and free(ptr)
>>> include/petscsys.h:1157
>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-freebsd-cxx-pkgs-opt_wii.log]
>>> /usr/home/balay/petsc.clone-2/include/petscsys.h:1157:88: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-linux-opt-cxx-quad_grind.log]
>>> /sandbox/petsc/petsc.clone-3/include/petscsys.h:1157:88: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-freebsd-pkgs-opt_wii.log]
>>> /usr/home/balay/petsc.clone/include/petscsys.h:1157:39: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-linux-pkgs-latest_cg.log]
>>> /sandbox/petsc/petsc.clone-4/include/petscsys.h:1157:25: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-linux-pkgs-opt_crank.log]
>>> /sandbox/petsc/petsc.clone/include/petscsys.h:1157:25: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
>>> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
