[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2016-04-08
Satish Balay
balay at mcs.anl.gov
Fri Apr 8 12:00:40 CDT 2016
I can confirm the 'analyzer' warnings are fixed in thi branch.
Satish
On Fri, 8 Apr 2016, Michael Lange wrote:
> Hi Matt,
> I just pushed the branch mlange/fix-plex-fluent-reader that re-enables the
> plex-fluent test cases and hopefully fixes these warnings. Can you please
> double-check this and merge to next/master?
> Thanks,
> Michael
> On 08/04/16 15:00, PETSc checkBuilds wrote:
> > Dear PETSc developer,
> > This email contains listings of contributions attributed to you by
> > `git blame` that caused compiler errors or warnings in PETSc automated
> > testing. Follow the links to see the full log files. Please attempt to fix
> > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are
> > unable
> > to resolve the issues.
> > Thanks,
> > The PETSc development team
> > warnings attributed to commit
> > https://bitbucket.org/petsc/petsc/commits/3f6dc66
> > Plex-Fluent: Add coordinates to the generated Plex
> > src/dm/impls/plex/plexfluent.c:408
> > [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-linux-analyzer_crush.log]
> > /sandbox/petsc/petsc.clone/src/dm/impls/plex/plexfluent.c:408:27:
> > warning: Array access (from variable 'coordsIn') results in a null
> > pointer dereference
> > https://bitbucket.org/petsc/petsc/commits/f732056
> > Plex-Fluent: Build Plex topology from face connectivity
> > src/dm/impls/plex/plexfluent.c:322
> > /sandbox/petsc/petsc.clone/src/dm/impls/plex/plexfluent.c:322:27:
> > warning: Array access (from variable 'faces') results in a null
> > pointer dereference
> > To opt-out from receiving these messages - send a request to
> > petsc-dev at mcs.anl.gov.
