[petsc-dev] Need help with Fortran code/compiler issue
Lawrence Mitchell
lawrence.mitchell at imperial.ac.uk
Fri Apr 8 03:23:24 CDT 2016
> On 7 Apr 2016, at 19:46, Barry Smith <bsmith at mcs.anl.gov> wrote:
> src/sys/classes/bag/f2003-src/fsrc/bagenum.F has the code fragment
> Subroutine PetscBagRegisterEnum(bag,addr,FArray,def,n,h,ierr)
> use,intrinsic :: iso_c_binding
> implicit none
> PetscBag bag
> character(*) n,h
> character(*) FArray(*)
> PetscEnum :: def
> PetscErrorCode,intent(out) :: ierr
> PetscReal addr(*)
> Type(C_Ptr),Dimension(:),Pointer :: CArray
> character(kind=c_char),pointer :: nullc => null()
> PetscInt :: i,Len
> Character(kind=C_char,len=256),Dimension(:),Pointer::list1
> do i=1,256
> if (len_trim(Farray(i)) .eq. 0) then
> Len = i-1
> goto 100
> endif
> if (len_trim(Farray(i)) .gt. 255) then
> ierr = PETSC_ERR_ARG_OUTOFRANGE
> return
> endif
> enddo
> return
> 100 continue
> Allocate(list1(Len),stat=ierr);
> Allocate(CArray(Len+1),stat=ierr)
> do i=1,Len
> list1(i) = trim(FArray(i))//C_NULL_CHAR
> enddo
> CArray = (/(c_loc(list1(i)),i=1,Len),c_loc(nullc)/)
> call PetscBagRegisterEnumPrivate(bag,addr,CArray,def,n,h,ierr)
> DeAllocate(CArray)
> DeAllocate(list1)
> End Subroutine
> which produces the following warning with one Fortran compiler:
> /Users/petsc/petsc.clone-4/src/sys/objects/f2003-src/fsrc/optionenum.F:35:0:
> Warning: 'list1.data' may be used uninitialized in this function [-Wmaybe-uninitialized]
> Do any Fortran programmers know if the code is correct or if this is an incorrect warning from the compiler?
This is occurring because the return value from allocate(list1(Len),stat=ierr) is not being checked and so list1 may be NULL later on.
This squashes the warning for me:
if (ierr .ne. 0) then
ierr = PETSC_ERR_MEM
return
endif
One should presumably do the same after the allocation of CArray as well.
It looks like the same change would apply in optionenum.F
Cheers,
Lawrence
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160408/2cc6f196/attachment.sig>
