[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2016-04-06
Wed Apr 6 13:25:19 CDT 2016
  My fault. Will fix.
> On Apr 6, 2016, at 9:00 AM, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing.  Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> to resolve the issues.
> Thanks,
>  The PETSc development team
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/943ccf5
> Vec IO: support large file sizes using local displacement
>  src/vec/vec/impls/mpi/pdvec.c:424
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/06/build_next_arch-viennacl_es.log]
>      /scratch/petsc/petsc.clone-4/src/vec/vec/impls/mpi/pdvec.c:424:10: warning: 'n' may be used uninitialized in this function [-Wuninitialized]
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/06/build_next_arch-linux-pkgs-valgrind_grind.log]
>      /sandbox/petsc/petsc.clone/src/vec/vec/impls/mpi/pdvec.c:424:10: warning: 'n' may be used uninitialized in this function [-Wmaybe-uninitialized]
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/06/build_next_arch-mswin_ps3.log]
>      C:\cygwin\home\sbalay\PETSC~1.CLO\src\vec\vec\impls\mpi\pdvec.c(424) : warning C4700: local variable 'n' used without having been initialized
>  src/vec/vec/impls/mpi/pdvec.c:429
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/06/build_next_arch-linux-pkgs-latest_cg.log]
>      /sandbox/petsc/petsc.clone-4/src/vec/vec/impls/mpi/pdvec.c:429:10: warning: 'n' may be used uninitialized in this function [-Wmaybe-uninitialized]
> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
