[petsc-dev] Adding support for new sparse BLAS inspector-executor routines in MKL
Richard Mills
richardtmills at gmail.com
Wed Sep 30 13:25:00 CDT 2015
Ha! Thanks, Barry -- your way with words is always appreciated. =)
Matt, the inheritance model *is* kinda sucky and broken but at least you
guys didn't use C++, so I'll take it. I will take a look at the different
subclasses (including the one that I wrote =) ) to refresh my memory about
how to do this correctly.
I need to get an initial implementation in place first, but I'll go ahead
and ask about how I'll eventually need to set things up in BuildSystem for
this. Perhaps I should follow a similar model to the MKL Pardiso support,
i.e., make the user explicitly ask for this? Something like
'--with-mkl_spmv2-dir=LOCATION_OF_INTEL_MKL'?
What is the workflow for making changes to BuildSystem these days? Do we
have this documented somewhere? I ask because I'll need to add something
for configuring the MKL inspector-executor stuff, and also because, in a
separate issue, I need to add support for the memkind library (
https://github.com/memkind/memkind). (Yes, Jed, I know you don't like it
but it's what we've got for now for using KNL MCDRAM. I hope someone comes
up with an intelligent middleware approach to dealing with this at some
point.)
--Richard
On Wed, Sep 30, 2015 at 8:06 AM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
> >> On Sep 30, 2015, at 9:48 AM, Jed Brown <jed at jedbrown.org> wrote:
> >> Matthew Knepley <knepley at gmail.com> writes:
> >>> Richard, this is somewhat subtle since PETSc's inheritance model is
> sucky
> >>> and somewhat broken. Look at
> >>> the factorization classes, AIJMUMPS etc., before coding anything.
> >> Richard wants to use the MKL implementations of stuff like MatMult and
> >> MatAXPY, not just factorization. So it doesn't look like AIJMUMPS.
> > Jed and Matt,
> > Remember Richard actually wrote the subclasses of AIJ for the Cray
> vector machine so you guys are teaching your grandmother to suck eggs.
> Where is @shitbsmithsays when you need it?
> > Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150930/030564dc/attachment.html>
